SANDING TIGHT PLACES,GOT ANY TIPS
Forum topic by a1Jim posted 11-24-2012 03:16 AM 9396 views 0 times favorited 46 replies Add to Favorites Watch
116906 posts in 3483 days
11-24-2012 03:16 AM
Topic tags/keywords: question
I’ve been working on my pie crust tilt top it’s a way past due project, Part of the reason it hasn’t been finished is all of the detailed sanding around the pie crust edge so far it seems like I’ve sanded around this edge 30 times. I have lots of power tools but these details really don’t lend them self to sanding with power tools with out destroying the detail.
So I was hoping some of you have tricks to sand on edges and details that a I don’t know about.
Her’es a photo of a similar detail.
I’d appreciate any and all suggestions
Thanks Jim
46 replies so far
View stevematis's profile
stevematis
58 posts in 3257 days
#1 posted 11-24-2012 03:41 AM
i would try to make a mirror profile piece and glue sand paper on it. But, because of the different curves, 2-3 different “tool” would be needed.
-- www.lignator.us
View ITSALLRITEWITHME's profile
ITSALLRITEWITHME
9 posts in 1924 days
#2 posted 11-24-2012 03:42 AM
Jim, I have two methods. First I always prefer cabinet scrapers and I have two that are small with wood handles, like old screwdriver handles. I will try to remember where I purchased them, Garrett Wade ( they have changed focus but may still carry these) or Japan Woodworker. You can also try a small chisel, used like a scraper.
I have also used psa sandpaper on small finely finished and shaped gaboon eboney sticks. I have more of these than I will ever use (left over from glass stop from an order of doors for a customer with too much money but very good taste) so if you email your address I will mail several to you and you can custom shape them
View JAAune's profile
JAAune
1780 posts in 2223 days
#3 posted 11-24-2012 03:51 AM
The only two methods I’ve employed that could be used in that situation are shop made profile scrapers and psa sandpaper stuck to a flexible card scraper or perhaps thin, flexible plastic.
Outside of that, I’d probably still end up doing mostly hand sanding with pieces of folded psa sandpaper. I like the folded psa around profiles because it’s stiffer than regular sandpaper and can somewhat hold its shape when flexed.
#4 posted 11-24-2012 04:02 AM
Thanks for the suggestion Steve
That would be wonderful if I could use that technique but because the profile is different as it circles the edge of the table it would not be possible. This technique is great for straight moldings .I’ve made molds the way you suggested by putting wax paper over the molding and then spreading bondo over it to form a mold and then using psa sand paper to the mold and then sand,it works great.
View Joe Lyddon's profile
Joe Lyddon
10038 posts in 3958 days
#5 posted 11-24-2012 04:54 AM
As someone says…
“Whatever works, works…”
#6 posted 11-24-2012 05:14 AM
Thanks guys sounds like some good Ideas I’m pretty sure I can’t make a scrapers work because of the changing direction and with so much variation.
Bill the sticks was something I was thinking about I have some Ipe that should work for me to make some. thanks for the offer and the help.
JAAune thanks for the help I have been doing the whole thing with psa sand paper and the right profiles would help.
Jonathan Thanks for reminding me ,I have the same sander and I can check the profile on the tad polls(rubber profile)
and see if I can make some work.
View Boxguy's profile
Boxguy
2541 posts in 2174 days
#7 posted 11-24-2012 06:57 AM
Jim, I would made a sanding tube. Consider using some hose or plastic tubing that is a little stiff, but would bend easily. Check the local big box in the plumbing isle for something with an appropriate diameter. It should be the diameter of the cove or just a little less.
Then I would wrap self-adhesive sand paper cut in a 1/2 inch strip around the hose on an angle like you would on a drum sander or baseball bat. Don’t let the strip overlap as it encircles the hose.
If you need more firmness in the sanding tube, another piece of smaller hose or even rolled paper inside the tube should help that.
I can sand lots of things with just my hand, but inside curves are too easy to distort. Unless the paper’s arc closely matches the arc of the wood, sanding will not be very efficient. One sanding tube may well match all the varied shapes and save you a lot of mold-making time.
Good luck.
-- Big Al in IN
View RussellAP's profile
RussellAP
3103 posts in 2193 days
#8 posted 11-24-2012 08:21 AM
you might try to make a sanding sponge like what they use for drywall. Id try to make one out of a damp sponge, not wet, just plyable, break the sandpaper down so it gets into the countours.
View Sheila Landry (scrollgirl)'s profile
9220 posts in 2826 days
#9 posted 11-24-2012 10:54 AM
I don’t know if this will help Jim, but I have this set of contour sanding grips that I use when I have difficult edges:
http://www.leevalley.com/US/wood/page.aspx?p=20183&cat=1,42500
It is from Lee Valley and I usually find one in the set that fits what I am working on enough to get me through the job. :)
Sheila
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6940 posts in 3341 days
#10 posted 11-24-2012 11:16 AM
Sheila beat me to it, Jim those contour grips she suggests are a life saver and often just what you need, and they are reasonably priced too.
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
View douginaz's profile
douginaz
220 posts in 3908 days
#11 posted 11-24-2012 12:44 PM
Wow, God bless you Jim, I can’t imagine sanding all those profiles. I have no idea how I would attack something like that. Only thing i can suggest is a couple of apprentice’s or a troop of trained monkeys. I have made profiles before using molding clay, I liked that better than the epoxy because you can custom make the finger holds. Other than that you are on your own Bud:)
Later,
Doug in AZ./
-- If you need craft books - please visit our small business at http://www.wittywife.com
View jaykaypur's profile
jaykaypur
4017 posts in 2314 days
#12 posted 11-24-2012 12:53 PM
Whichever tip/idea you decide to use, it looks to me like a lot of tedious but precise sanding. I am sure that whatever you do, it will turn out just fine.
I’m just glad I read the blog and saw Sheila’s idea. I’ve already ordered a set.
-- Use it up, Wear it out --------------- Make it do, Or do without!
View Roger's profile
Roger
20904 posts in 2710 days
#13 posted 11-24-2012 01:01 PM
You’ve definitely got your sanding cut out for ya. I also like Sheila’s tip & link. I think it would be possible to create your own contours using some scraps. However you do it, you’ve got yer sanding work cut out for ya… OH, I already said that. Good luck
View Gary's profile (online now)
Gary
9298 posts in 3339 days
#14 posted 11-24-2012 01:34 PM
Jim, if you remember, GaryK buile one of these a year or two ago. Contact him and see how he did it. I’m sure he’d answer a pm
View CharlesNeil's profile (online now)
CharlesNeil
2233 posts in 3777 days
#15 posted 11-24-2012 02:11 PM
Jim, having done a few of these :) , we use the little profile sanders Sheila shows. We do cut them in half and 1/ 3 so as to get into the tight corners. Also try getting some fingernail emery boards, one side is course , the other fine. You can cut angles on them for the really tight corners. We also use the profiles pads and emery boards for carvings
showing 1 through 15 of 46 replies
