Wooden Slab - now what?
Forum topic by MT_Stringer posted 11-23-2012 11:21 PM 940 views 0 times favorited 3 replies Add to Favorites Watch
View MT_Stringer's profile
MT_Stringer
3183 posts in 3467 days
11-23-2012 11:21 PM
Topic tags/keywords: question oak
I managed to score a couple of slabs from a White Oak tree that had been cut down for about a year. The two slabs are approx 16 inches across x 2 inches thick.
My goal is to make lazy Susans out of them. They are pretty even so a few minutes with the belt sander should be all that is needed.
My question is what should I do about the newly fresh cuts? I have seen some insect holes so should I treat the wood in some sort of way or ….
I guess my plan is to simply give them a good coating of dewaxed shellac and call it a done deal.
I also have some smaller pieces to make candle holders and holders for salt and pepper, etc.
Your thoughts appreciated. I have never dealt with wood straight off the vine! :-)
Thanks
Mike
3 replies so far
View Don W's profile
Don W
19041 posts in 2803 days
#1 posted 11-24-2012 01:15 AM
You should seal the end grain to slow moisture escape. Anything you have should help. I use old paint, but shellac, varnish or poly will work. If its been down for a year you can store it inside.
View oluf's profile
oluf
260 posts in 3275 days
#2 posted 11-24-2012 02:44 AM
If you have an electric oven that is large enough, I would reccomend baking it in the oven at the lowest tempurture that you can for two hours. That will be kiln dry and will kill any bugs or bug eggs.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
MT_Stringer
#3 posted 11-24-2012 02:51 AM
@oluf – I can do that. Thanks.
