| Forum topic by CudaDude | posted 183 days ago | 967 views | 1 time favorited | 18 replies | ![]() |
183 days ago |
Did a search here and a google search and didn’t come up with a definitive answer. I’m building a play kitchen for my daughter and will be using 3/4 MDF for the paintability. My question is, what method of joining should I use? Can’t use the table saw yet so my options are dadoes and rabits with router, kreg pocket holes, biscuits or just normal right angle edge to face screwed together. Thanks in advance Gary -- Gary |
18 replies so far
#1 posted 183 days ago |
I’d suggest dadoes and and rabbets. IMO, biscuits add little strength to a joint. Good for alignment, though. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#2 posted 183 days ago |
Biscuits or dados will be more predictable for you if you just MDF can be screwed together but it requires meticulous Many people do it, but I don’t recommend pocket screwing |
#3 posted 182 days ago |
Good advice so far. But since it hasn’t been mentioned already, use eye protection and a good dust mask, along with any dust collection system you may have. MDF dust is super funky toxic stuff that you don’t need anywhere near your lungs. -- Brian in Arlington, TX - Laziness is the foundation of efficiency. |
#4 posted 182 days ago |
MDF for a box that might get some movement? It’s pretty finely compressed sawdust that works great for tops and panels attached to some real wood but on its own I’d be concerned about fastener tear-out. I’d probably go rabbet joinery with glue and a boat-load of nails. |
#5 posted 182 days ago |
Check out the following links. http://www.mcfeelys.com/product/0612-CDA/14quot--20-x-34quot-Offset-Barrel-Nuts |
#6 posted 182 days ago |
Thanks for the links MrRon. Seriously considering going that route since it will give me the ability to break it down for storage once she outgrows it. Having never designed anything with these barrel nuts, would I need the centered or offset? -- Gary |
#7 posted 182 days ago |
MDO (medium density overlay) might be used as well. It paints up nicer than MDF. |
#8 posted 182 days ago |
Well Gary do you have a kregjig I build everything with my K-2 its easyer to use the a biscuits or dados and remeber to set the cluth on your drill to 6 or 7 and use a nickle and a dime to set your stop collar the dime is for more meat to screw into. |
#9 posted 182 days ago |
I have used both biscuits and Kreg pocket hole jig when building some cabinets and jigs for the shop. If I were making something from MDF today, I would use my Kreg pocket hole jig for the ease and speed of getting the job done. I echo David Dean’s comment regarding setting the clutch on your driver to avoid stripping out the screws. Good luck and have fun. -- Rick |
#10 posted 181 days ago |
Cudadude; Either one would work as long as the thickness of the material is 3/4” or more. If under 3/4”, use the centered barrel nut. I haven’t used a Kreg jig, so I don’t know if they have screws suitable for MDF. |
#11 posted 181 days ago |
I still would be concerned about tear-out in MDF…”skin” side probably fine but the raw side that it screws into??? If you want to be able to dismantle, then inside corner cleats made of whatever wood you have. MDF gets attached to them rather than to another piece of MDF. |
#12 posted 181 days ago |
I’ve not worked with MDF much until this weekend. I’m replacing my TS extension plates with a router table on the left and a larger table on the right. The router table is made from three layers of MDF that will be topped with formica. The other table will have an MDF/formica top, but will not be quite that thick. I was not prepared for how much dust MDF creates. I had the vacuum and air scrubber going most of the time, but still the shop filled with fine paper dust. It’s everywhere. When this little project is over, I’m going to have to wash down the entire shop. |
#13 posted 181 days ago |
I built a TV stand out of MDF about 6 years ago and it still stands today. I would suggest hand-screwing the screws. If you take your time and pay attention you can get a sense of just how much torque the MDF can take before splitting or striping out the screw. I used all butt joints. |
#14 posted 181 days ago |
MDF is not fit for man or beast. Nasty, cancer causing, formaldehyde infested stuff. Rich;) -- Rich;) -"Dada make a big mess?" "Yes Dada made a big mess." |
#15 posted 181 days ago |
Had some pieces of MDF laying around so I did some experimenting with the kreg jig. Doesn’t seem to be a question of strength with a edge to face joint even before the glue dried. I’ll try to explain the problem I’m having. On the face part of the joint that I’m screwing into, I need to drill a pilot hole at the same angle of the pocket hole to keep the MDF from pulling up between the joint. Any suggestions on how I might drill the pilot holes at that angle? -- Gary |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3555 |
15813 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2847 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2742 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
