Question on drying
Forum topic by mIps posted 11-21-2012 04:29 AM 948 views 0 times favorited 5 replies Add to Favorites Watch
View mIps's profile
mIps
200 posts in 2290 days
11-21-2012 04:29 AM
A neighbor was pruning their maple tree and I talked them out of a branch about 2” in diameter. How should I go about drying it so I can work it properly.
-- Be honest, honorable, kind, work hard, and generally be awesome.
5 replies so far
View WDHLT15's profile
WDHLT15
1797 posts in 2712 days
#1 posted 11-21-2012 04:43 AM
If you do not dry it slowly, it will split and crack if you turn your back on it. Put it outside, under cover, and let nature take its course for 6 to 8 months. It needs protection from rain, but also good air flow. Do not put it in a heated or cooled space until it has had time to season outside, or it will split to spite you.
View Nomad62's profile
Nomad62
726 posts in 3194 days
#2 posted 11-21-2012 05:31 PM
What would you do with it? Anything that small should dry out okay, but it will tend to split as any round piece will. Limbwood generally holds plenty of stress, making it unstable; turners like to spin stuff out and let it dry, then finishing it off after the “blank” dries completely to remove the warpage. Flat boards rarely stay that way, making small pieces the choice to rely on. Any way you choose, it’s best to paint, wax, or otherwise seal the ends and let it set in a cool dry area for a while, with maple that small probably a couple months will do it.
View mIps's profile
mIps
#3 posted 11-22-2012 08:53 PM
Nuts. not the answer I was hoping for. Oh well.
View Knothead62's profile
Knothead62
2600 posts in 3197 days
#4 posted 11-22-2012 09:31 PM
Coat the ends with Anchorseal or a latex paint to keep the drying under control to prevent cracking.
117417 posts in 3813 days
#5 posted 11-22-2012 09:52 PM
If you can think of something you want to turn it into you can turn it on a lathe,but you would still have to wait for it to dry after you rough it out.
