Insulation in the shop
« back to Coffee Lounge forum
Forum topic by thetimberkid posted 461 days ago 213 views 0 times favorited 7 replies Add to Favorites Watch
View thetimberkid's profile
thetimberkid
1944 posts in 596 days
461 days ago
Topic tags/keywords: question
Hey, as you probably know I am in the prosses of building my new shop.
http://lumberjocks.com/jocks/thetimberkid/blog/5574
I was wondering what type of insulation you have in your shop and what your opinion is of it. I am thinking about using spray foam do you have any comments on this product?
Oh yeah there will be a blog update soon!
Thanks
Callum
View Davesfunwoodworking's profile
Davesfunwoodworking
259 posts in 768 days
461 days ago
I think for your shop You might want to go with rolled or blow in. Thats what I would do.
-- Davesfunwoodworking
View PurpLev's profile
PurpLev
2733 posts in 541 days
461 days ago
if you still havent put up the sheetrock on the framing – you’re better off going with the fiberglass-type insulation, it comes in rolls, is darn cheap (compared to the spray foam) and is much easier/faster to install than the spray foam as well. the good thing about the spray foam is if you already have the walls up on the frame, and need to insulate those – you can use the spray to get in the wall without having the remove all the sheetrock. (but that involves cutting relief holes to spray into the wall and patching those later…)
14914 posts in 744 days
461 days ago
None Callum, I just go outside if it gets too hot. LOL
3710 posts in 872 days
461 days ago
Hi Callum;
I would / did use rolls if fiberglass insulation. If you want to fish a wire later on, foam insulation will make it impossible.
Also, it is usually cheaper to hire a professional insulating company to do the job for you.
And much less itchy!
On my construction projects, it is often less money to have the job done, than I can buy the materials for!
Which makes me very happy.
Get a few bids and references, before hiring someone. Also, CALL the references! They aren’t much good if you don’t follow up!
Hope this helps;
View brunob's profile
brunob
1469 posts in 1062 days
461 days ago
I did the rolled fiberglass in my shop. Went quick and the shop is toasty in the winter so it must be working. 6” in the walls and 12” in the ceiling.
-- Bruce from Central New York
View Wooder's profile
Wooder
163 posts in 1079 days
457 days ago
I too used roll type. r13 in the walls and r19 in the ceiling. Very cheap to do. Small shop only 16×20. 10k btu a/c for summer works great and small wood heater for winter is just right for our mild winters.
Jimmy
-- Jimmy
View Jimthecarver's profile
Jimthecarver
427 posts in 678 days
457 days ago
I used both rigid styrafoam and fiberglass for the best R rating…This desert gets hot in the summer and very cold in the winter….I love that pellet stove!
