| Forum topic by Chipper | posted 105 days ago | 138 views | 0 times favorited | 2 replies | ![]() |
105 days ago |
I was doing some fence repair work and broke the handle on a borrowed shovel. Since I believe that you should always return a borrowed tool in the same or better shape than you started out with, and this shovel has sentimental value for the owner, I am replacing the shovel handle instead of just buying them a new shovel. Much to my surprise, the original handle actually has a significant bend at the end of the part that goes into the shovel. ( I had a heck of a time getting the old part out). The replacement handle I came up with is long enough, but straight. I want to attempt to put the new handle in after heating it up (bending it). My question: can I just heat the end of it in bucket of boiling water (easy) or do I need to set up a steam box (pain :) )? -- Steve (Plano, TX) |
