| Forum topic by BDFan1981 | posted 179 days ago | 793 views | 0 times favorited | 26 replies | ![]() |
179 days ago |
Topic tags/keywords: circular saw cordless circular saw battery operated moto-tool Here is my theory of why the cordless (and I mean battery operated) circular saws don’t work well: With regards to the OSHA standard that the maximum blade tip speed limit that is 18,000 SFPM, a max RPM of 1000 on the smallest saws in the category don’t do justice. Henceforth, for example, would you have envisioned a cordless saw with a 3-3/8” dia. blade as having its motor spin 20,000 RPM to equal the efficiency of the larger, corded saws? I repeat: 1000 RPM is not enough and especially so for a blade size as small as 3-3/8”. Case in point: even cordless battery-operated “Moto-Tools” can spin between 10,000-30,000 RPM easily. SAW BLADE SPEED CHART (all figures calculated using the max of 18,000 SFPM) Is there a reason that the early cordless motors can’t do 20,000 RPM efficiently (on the 3-3/8” cordless saws)? ~Ben |
26 replies so far
#1 posted 179 days ago |
Ben: That being said, 20,000RPM is certainly achievable in a battery powered motor, but with the needed amps to kick through say, a 4X4, you would deplete the battery in very, very short order. So they slow it down and make the blade smaller and up the amperage. You end up with a sub-standard effort that is OK for some basic cuts, with you still changing batteries faster than your charger can keep up. -- Paul, Tennessee, http://www.tsunamiguitars.com |
#2 posted 179 days ago |
The corded skill worm drive saw only does 4600 rpm no load, the de walt 18 volt does 3700 rpm no load….. I see a problem with your premise as well…. As an owner of 8 different battery powered saws, They work excellent, and because the evaluation depends on the task, sometimes much better than corded, and sometimes corded much better than battery powered. Is there a reason that the early cordless motors can’t do 20,000 RPM efficiently (on the 3-3/8” cordless saws)? A 3 hp delta uni saw on 220v only does 4700 rpm blade speed. That makes it’s spfm only 6157 The skil 4365 and the dewalt 3514 So please clarify your point. -- Who is John Galt? |
#3 posted 179 days ago |
I have often though one of these would be handy for places where I need to bob off the end of a board and am out of range for a cord. One of these days I will happen across a deal on one, until then,,,I have about 500 ft of extension cord. -- I do not have attention deficit dis,,,,,,,,,,,,,,,,,,,,,,,hey look ,it's a bunny |
#4 posted 179 days ago |
I have to keep all my wood in another room, so I used to use mine for cutting up planks. Too many times I ran out of power, and one day I looked up and saw the receptacle in the ceiling…and bought a Rockwell Versacut, which I am not thrilled with, but it gets the cut done. -- Paul, Tennessee, http://www.tsunamiguitars.com |
#5 posted 179 days ago |
I love my 6 1/2” makita. I guess i just accept its limitations. You really cant expect a battery op circular saw to run forever on 1 battery. -- Building quality in a throw away world. |
#6 posted 179 days ago |
”Delta Uni Saw, on 220v only does 4700 RPM, that makes its spfm only 6157.” I assume you meant sfpm (surface feet per minute). 10” diameter blade X pi = 31.416” circumference. But, in any case, the manufacturers had to keep battery drain down to a level that would not fry the batteries. The Milwaukee 6 1/2” with a 28volt battery does a fair job, but to get the kind of power out of a 28 volt saw to compete with a 15amp 120 volt saw, the battery would have to put out 64 amps. The battery would weigh about 50 lbs; ain’t going to happen. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#7 posted 179 days ago |
I used radius instead of diameter .262×5x4700 = 6157 I still am trying to grasp the theory and also defending cordless a little. It may also help if you defined the qualitative part of the argument… I always keep both with me, ready to use for their specific purposes…. But I did notice the moment I got my first cordless saw, I started reaching for it more often, for more purposes. That is to say it is my goto when I need a saw and I only find my self using the other less, as the more specialized saw, and that I now have three times as many cordless circular saws than corded. -- Who is John Galt? |
#8 posted 179 days ago |
I had a cordless miter saw for awhile. Great tool in terms of Before the widespread availability of AC power there were |
#9 posted 179 days ago |
Joey, to be honest, I think we all would in one way or another like to kick the “cord” habit. But some things we get used to, like having more than enough power to run a circular blade through a piece of wood. Why would anyone want to haul a Skil worm saw around? What horses. Like moving the table saw, instead of the wood! I bought an old 68’ Skill worm at a garage sale for $2, cleaned it all up and that thing will easily cut through railroad ties without losing any RPM. (Within the limits of the blade depth, of course.) But I don’t use it for daily things. It actually is a bit too awkward for my old hands. But the sheer torque would never, ever be matched by any battery unit. -- Paul, Tennessee, http://www.tsunamiguitars.com |
#10 posted 179 days ago |
Don’t tell that to the chevy volt crowd…they are working very hard to match it every day. Besides, my next cordless saws will be either solar or hydrogen fuel cell :) P.s. I understand the power and stamina sides of the idea, just not the theory that speed plays into it. They are already generating speeds comp. to corded saws. And that many of the newer larger cordless saws far out perform the first entries into the market.. which, ironically, I use the later most because they are smaller. -- Who is John Galt? |
#11 posted 179 days ago |
They are trim saws. You aren’t going to rip 2X material along it’s length. They serve a purpose and mine has been extremely handy. |
#12 posted 179 days ago |
In my mind, noise is the only advantage of cordless circular saw. The cordless saws I’ve seen in use were half as loud as their corded competitors. I considered buying one for that fact alone. I abandoned the idea when I realized that I only use my current circular saw about twice per year. It terms of performance, the cordless saws seem to work well enough. But I only used them to cut a handful of 2×4 and 1×4 softwoods. Of course, I doubt I’ll ever buy another cordless tool ever again. Unless I need a quieter tool or find myself working someplace with electricity issues. I never work more than 10-20ft from an AC outlet. I don’t find rechargable batteries to be any less hassle than dealing with a cord. And I have more confidence it the reliability and longevity of a corded tool. JMHO. |
#13 posted 178 days ago |
I love cordless tools for the convenience and portability, but as others have said, they do come with limitations. I use my cordless circular saw often to break down sheet goods and it does a great job at that. You just have to pick the right jobs for the tool. -- John, BC, Canada |
#14 posted 178 days ago |
The reason they don’t work well is because you can’t generate enough power with a battery to cut through anything-that’s the real reason the blades are so small, an 18V motor would have a helluva time running a 71/4” 20T blade through the air let alone through a piece of wood. |
#15 posted 178 days ago |
RPM and torque is irrelevant here. With proper motor and/or gear ratio you can have them anything you want and at top efficiency. The limitation here is battery energy capacity. Unlike drills, circular saws are much more energy thirsty. Ripping 2×4 might require several hundred watts. A 3Ah 18V battery will last about 5 min of continuous use with that kind of energy expenditure. As a result cordless saws are designed small and for light use. |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15749 |
Hand Tools
2028 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
