I need a sharpening system
Forum topic by RussellAP posted 11-20-2012 01:55 PM 1648 views 1 time favorited 24 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2194 days
11-20-2012 01:55 PM
Here is what I’ll be sharpening and if you all have experience with a particular machine that will do what I need done, let me know what it is and your experience with it.
I’ll be sharpening planes and lathe chisels mostly.
The lathe chisels don’t need to be absolutely honed, just a decent edge will do, but the planes I want to be honed very sharp.
I’d also like something that doesn’t require a footprint in my shop. I’m already tripping over tools as it is. It needs to be something that can be easily put away.
Thanks in advance.
24 replies so far
View WoodyG's profile
WoodyG
33 posts in 3080 days
#1 posted 11-20-2012 02:16 PM
Well, Russ…...you need more than one and the price doesn’t neccessarily reflect its usefullness. I have a great
Tormek for planer blades and hand plane blades but I don’t like it for lathe tools…too slow….. I have two glass sanders which I made and they are perfect for honing straight and flat hand tools. I have 3 diamond plates for hand knives and 1 other diamond stone set for other knives. Buddy, I’ll tell you now you will never stop sharpening tools and you’ll always be looking for better tools to do it with but you will need a GOOD bench grinder. I chose the 8” Delta because I get a nice discount at Lowe’s and it is well supported by Delta.
There are a huge number and variety of sharpening aids and “ebay” has several thousand to choose from but all I can say is be comfortable when you sharpen.
-- WoodyG
View waho6o9's profile
waho6o9
8100 posts in 2484 days
#2 posted 11-20-2012 02:36 PM
Yeah buddy
Tormek
Scary Sharp
DMT
Waterstones
MDF with green honing compound
+1 for WoodyG
View Biff's profile
Biff
126 posts in 1921 days
#3 posted 11-20-2012 03:02 PM
I love the Tormek system for my lathe tools. I’ve found it is only really slow when you are initially changing the grind of a chisel. Otherwise for basic sharpening it goes quickly after you’ve done it a couple times. Results are fantastic. As a bonus, I could perform surgery with my kitchen knives! Another bonus is no sparks!
-- Interested in Oregon property? Visit me at http://www.willamettepropertiesgroup.com
View Kreegan's profile
Kreegan
1452 posts in 2054 days
#4 posted 11-20-2012 03:04 PM
Do you have a bench grinder already? That’s what I use for lathe chisels. The jig for fingernail/Ellsworth grinds is easy to make. You can use a grinder up to a certain point for plane irons, but then you’ll want a fine honing stone and a strop.
Rich;)
View ShaneA's profile
ShaneA
6890 posts in 2506 days
#5 posted 11-20-2012 03:09 PM
I thought you had the WS 3000 Russ, if not, that is an option for you. Sort of a mechanizied scary sharp method, plus should be good for the lathe chisels, gouges too.
View wunderaa's profile
wunderaa
248 posts in 2110 days
#6 posted 11-20-2012 03:15 PM
For your reading pleasure, let me suggest Leonard Lee’s book, The Complete Guide to Sharpening
In the book, Lee gives details on sharpening everything from chisels to scissors, plane irons to axes. He also does a great job of summarizing the equipment he would recommend to accomplish what he has discussed in each section. It makes for a good read and an even better reference.
For your situation, I could imagine a recommendation of a honing guide, and a series of diamond plates or water stones for your planes and a grinder and decent rest/jig for your lathe tools. Really up to your preferences.
View lumberjoe's profile
lumberjoe
2894 posts in 2155 days
#7 posted 11-20-2012 03:55 PM
For me gouges go to the grinder, chisels, skews, and plane irons go to the stones. I have jigs and/or honing guides for everything. I practice freehand with some crappy buck bros chisels and a crappy buck bros plane iron, but I don’t have the muscle memory down good enough yet to put away the Veritas MK II
View Mosquito's profile
Mosquito
9216 posts in 2199 days
#8 posted 11-20-2012 04:02 PM
I sharpen freehand on DMT’s up to X-Fine, and then finish on a 6000 grit King water stone. The DMTs work pretty well. I’ve got an X-X-Fine DMT (8000 grit) but I wasn’t happy with the edge I was getting with it, so I tried a cheap King water stone. I’m happier with it, and I think I may buy another water stone down the road.
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
4883 posts in 2400 days
#9 posted 11-20-2012 05:59 PM
I think it’s a 2 tool (or system) set up. Scary Sharp or a Worksharp for the plane blades, and a slow speed bench grinder with a Wolverine jig for the lathe chisels. The Wolverine could be a shop built replica, and the grinder should have the white wheels. I used Scary Sharp for a lot of years and it worked really well, but I don’t remember pulling out my glass plates since I got a Worksharp. It great for your bench chisels as well. I have a Tormek, but it does have a footprint, and you have to pull out the water and get it set up…..to me, that means it doesn’t fit your criteria.
View Don W's profile
Don W
18606 posts in 2475 days
#10 posted 11-20-2012 06:18 PM
I good grinder and a few DMT’s and be done with it.
View ETwoodworks's profile
ETwoodworks
92 posts in 2600 days
#11 posted 11-20-2012 06:18 PM
I love my WS3000 it works perfect for chissels and plane irons. When it comes to lathe knives i just freehand them on top and get plenty good enuf results in just seconds. I got really lucky and got it off CL for $125 with 2 extra glass plates and the wide blade jig.
-- Building quality in a throw away world.
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2017 days
#12 posted 11-20-2012 06:27 PM
If I were doing it all over again, I’d buy:
For everything except the lathe tools:
- (2) double sided DMT diamond plates (XC/C & F/XF)
- A double sided 4000/8000 waterstone
- A $12 side clamp sharpening guide
Then, I’d make a jig like this:
http://www.lie-nielsen.com/pdf/AngleSettingJig.pdf
Here’s how it works: http://www.youtube.com/watch?v=1F7q5WGb4ZA
My example of the jig took less than 30 minutes to make, it’s not as nice as the LN “show” version.
The DMT’s are for flattening backs, and the XC will also work to flatten the water stones. A DiaFlat is better, and a good future purchase, but I used an XC for years before the DiaFlat was available.
All of my primary bevels are shaped on the XC DMT, then the guide is moved to create a microbevel on the 4000/8000 water stones. I use the next stop up on the jig for the microbevel. Most sharpening touch-ups are the micro ONLY, on the 8000 stone. The primary gets nothing beyond the DMT XC.
For example… on a typical bench chisel, I’ll shape the primary bevel using the 30 degree stop ‘till I feel a wire edge, reset the chisel to 35 degrees, and do 5-7 strokes on the 4000, and 5 or so strokes on the 8000. DONE! Touch-ups get reset with the 35 degree stop, and a few strokes on the 8000. That’s it, for incredibly sharp, easily repeatable results!
Backs get XC-C-F-XF DMT, and nothing else. Backs need to be FLAT, not perfect mirror polished. The DMT XF is plenty fine for this.
If the microbevel gets more than 1/16” wide, I hit the XC, at the primary jig setting, until the microbevel shrinks to a hair, then go back to the microbevel setting and the 4000/8000 stones. It takes longer to type this than to do it.
This is all I use any more for planes, chisels, marking knives, etc…
For the lathe tools:
- A decent bench grinder, 1800 or 3600, doesn’t matter to me.
- 60 and 120 grit friable wheels.
- A Wolverine jig & too rest set.
I have a Tormek, but I rarely use it. The main use is for carving tools, where it’s indispensable. If I didn’t have carving tools, I’d sell it. I also have a drawer full of unused guides, stones, sandpaper on glass… Want to buy them? ;^)
Don W
#13 posted 11-20-2012 06:33 PM
Not to steal Russel’s thread, but it is the same line of question. I hate waterstones and I don’t understand why you’d go from a dmt to waterstone when a 3 micron dmt is equivalent to a 8000 grit waterstone.
I finish with the dmt and it works great, so what is the advantage to starting with DMT’s and finishing with waterstones?
RussellAP
#14 posted 11-20-2012 06:50 PM
Don, where is a good place to buy DMT?
Don W
#15 posted 11-20-2012 07:02 PM
I don’t really know Russ, I got mine off eBay on a buy it now. I was just in the right place at the right time or I’d still be using oil stones. And that wouldn’t be a bad thing either.
