what kind of pine wood to use.
Forum topic by nate22 posted 181 days ago 578 views 0 times favorited 9 replies Add to Favorites Watch
View nate22's profile
nate22
360 posts in 1042 days
181 days ago
I have been making furniture for a while now and I use pine. And the pine I use has a lot of knots in it. What is the best kind of pine to use for furniture so it doesn’t have so many knots in it. I have heard and read a lot of guys use yellow pine is that a good one or not. Any thoughts would be helpful.
-- K & N Furniture Middlebury, In.
9 replies so far
View Lee Barker's profile
Lee Barker
1884 posts in 1017 days
#1 posted 181 days ago
Nate, here I get stuff called Eastern Soft Pine. It is furniture grade, which means knots, but I can cut around the large ones quite successfully. The rest of the material has very little grain (it looks like vanilla pudding) so edge gluing to get better yield is a no brainer. The stuff is really soft, but it machines nicely. It comes to me 15/16 and I can skim two sides on the planer and get 7/8 which is good visually.
Kindly,
View lumberjoe's profile
lumberjoe
2396 posts in 415 days
#2 posted 181 days ago
I’m not sure the exact species, but my local mill stocks plenty of “furniture grade” pine. It’s as Lee describes above. I have purchased quite a bit of it but i use it for mock-ups and test pieces during builds. It is VERY soft, the grain is really uninteresting, and overall I hate working with pine (finishing is a nightmare also). It’s not much cheaper than poplar, so I just go the poplar route now.
-- http://www.etsy.com/shop/KandJWoodCrafts
View Tennessee's profile
Tennessee
1089 posts in 681 days
#3 posted 181 days ago
I’d make the switch to poplar, like Joe says. if you pick out some of the heartwood poplar, some yards and big box stores will discount it, since a lot of people don’t like the greenish tint, which when stained properly, looks simply grand.
-- Paul, Tennessee, http://www.tsunamiguitars.com
View whitebeast88's profile
whitebeast88
1854 posts in 357 days
#4 posted 181 days ago
spruce is a better board i have found.i’ve used it on multiple projects and it looks better than a knotty pine.just my opinion.
-- It don't have to be straight,it's just a suggestion!!!
View bruc101's profile
bruc101
526 posts in 1708 days
#5 posted 181 days ago
Clear & Better SYP…Southern Yellow Pine
Clear & Better Arkansas Pine..almost the same as SYP
I was trained on SYP, love it and still use it today from furniture to residential and commercial cabinetry.
stepback china cabinet built in the 80’s from SYP, photo was taken a couple of years ago.
-- Bruce http://plans.testsitem3.info http://www.sawmillgirls.com
View redryder's profile
redryder
1587 posts in 1268 days
#6 posted 180 days ago
I’ve always liked Pine for many reasons. I had no idea there were so many different kinds of Pine out there until I read this web site. You can click on each individual type and you will get lots to read about.
Good luck…...............
-- mike...............
View mtenterprises's profile
mtenterprises
623 posts in 859 days
#7 posted 180 days ago
It’s (K)not the species of wood it’s the grade the better the grade the less knots. But if you can do it correctly sometimes you can make your cuts around the knots leaving you with perfect select pieces to your project. I just did this on a kitchen stool for my wife, (k)not a knot in it. Then on the other hand sometimes knots enhance the project if you can place them in stratigict locations.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View Jim Jakosh's profile
Jim Jakosh
7246 posts in 1272 days
#8 posted 179 days ago
Buy clear pine. It is from a location on tree with the minimum of branches and cost a bit more than knotty pine
-- Jim Jakosh.....Practical Wood Products...........Learn something new every day!!
View RussellAP's profile
RussellAP
2394 posts in 453 days
#9 posted 179 days ago
Yellow pine is for construction or rustic furniture. In face most pine is rustic if you ask me. I don’t think I could go back to something you can scratch with a finger nail after working with hardwoods. Sure pine is easy to work, but you can’t keep it clean while you work, it mars easily, and it gunks up your tools.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
