Ideas needed on this !
Forum topic by jaykaypur posted 11-19-2012 04:03 PM 1479 views 0 times favorited 11 replies Add to Favorites Watch
View jaykaypur's profile
jaykaypur
4017 posts in 2280 days
11-19-2012 04:03 PM
Topic tags/keywords: question walnut carving shaping arts and crafts rustic
I have made this out of walnut—-a small serving board and knife—-and I want to make an indentation/hollow to hold the small jar. It measures 8’’ x 5’’. I only want it about 1/8’’ to 1/4’’ deep….just enough to hold thejar in place. I dont have a forstner bit that big—2 1/4’’—and was wondering if anyone had any ideas.
So far I have thought of a hole saw and chiseling it out or….using a small circular sander to make a depression. I want to keep the top of the piece as smooth as possible or I would just make small frame for it.
Any and all help is appreciated. Thanks…...........J
-- Use it up, Wear it out --------------- Make it do, Or do without!
11 replies so far
View waho6o9's profile
waho6o9
8067 posts in 2449 days
#1 posted 11-19-2012 04:12 PM
http://lumberjocks.com/topics/17827
Or, mark your circle and freehand it with a router.
View grizzman's profile
grizzman
7836 posts in 3176 days
#2 posted 11-19-2012 04:13 PM
why dont you use a router, free hand it, i do this all the time, just go slow and always pull the router towards you, then sand the edge over so its smooth …
-- GRIZZMAN ...[''''']
View JNP's profile
JNP
113 posts in 2450 days
#3 posted 11-19-2012 04:23 PM
Do you have a drill press? If not it is tough to get the sides (outline) of your indent to be perfectly flat with a hole saw but if you’re only going an 1/8 you may be okay. If so, use your hole saw to score the proper depth then freehand rout. Either way, this will give you an error factor of the kerf thickness of the cutter so you don’t have to go to the actual outside of the line.
-- Jeff
View Monte Pittman's profile
Monte Pittman
27688 posts in 2210 days
#4 posted 11-19-2012 04:29 PM
I have a palm router that i absolutely love for doing freehand routing. I also have that size forstener bit.
-- Mother Nature created it, I just assemble it.
View Joshuah's profile
Joshuah
152 posts in 2565 days
#5 posted 11-19-2012 04:35 PM
I agree with the others and say free hand with a router. Though if you are not comfortable making the circle then JNP’s idea witht the hole saw the routering.
-- -Joshuah
jaykaypur
#6 posted 11-19-2012 04:51 PM
Well…....................some great ideas and tips and if I had a router….well, I wouldn’t have this problem!!!!!
Maybe Santa will bring me one or I could just drive up to Monte’s and borrow his forstner bit! LOL
View JNP's profile
JNP
#7 posted 11-19-2012 06:44 PM
Okay. I think you’re going to have to buy the forstner bit.
- start with your largest hole saw and move progressively down in diameter then chisel out the remaining ridges
- if you have the drill press and a beam circle cutter I’m guessing you could hog out the material that way
- use chisels and cross hatch the area to get down the to appropriate depth then pop out the remaining bits and scrape/sand the bottom smooth
- slice the top off your piece at 1/8 or 1/4” thick, cut the hole all the way through that and reglue/sand to blend.
-- Jeff
View Ted's profile
Ted
2838 posts in 2083 days
#8 posted 11-19-2012 07:15 PM
Other than running out and buying a router, the hole saw seems to be your best option. You will have to remove the centering bit from the hole saw, unless you want a nice “drain” hole in the middle of your recess. However, without the centering bit that hole saw is going to dance all over the place and ruin your piece. Unless!!! (brilliant flash, totally awesome idea coming up…)
Before you take the centering bit out of the hole saw, drill a hole through a piece of scrap wood. Then clamp the scrap wood to your work piece, remove the centering bit from the hole saw and using the scrap piece as a guide, drill to your desired depth.
I use this trick for making larger holes where a hole already exists, such as for door knobs.
-- You can collect dust or you can make dust. I choose to make it.
116807 posts in 3449 days
#9 posted 11-19-2012 07:44 PM
Monte Pittman
#10 posted 11-19-2012 08:05 PM
By the way, you’re welcome to come and use my forstener bit
jaykaypur
#11 posted 11-19-2012 09:55 PM
Thanks for all the great tips. I ended up using my drill press with a 2’’ sanding disc. I had to work it all around the perimeter of the hole to get it to 2 1/4 and it worked out great. Thanks again ….............J
