HF 12 inch disc sander
Forum topic by pantango posted 11-18-2012 07:50 PM 2119 views 0 times favorited 11 replies Add to Favorites Watch
View pantango's profile
pantango
51 posts in 2034 days
11-18-2012 07:50 PM
Hello,
Went to HF to get the 12 inch disc sander from central machine. I noticed on the tag “Motor: 120V, 22.7 amps (start), 1.25 HP, 1750 RPM” .
22.7 amp start? Won’t this trip a 20 amp breaker? Do I need to run a dedicated line for this machine?
Wondering if anyone has one for home workshop use
Thanks
Dean
-- Hate how work gets in the way of my hobby!!
11 replies so far
View toolie's profile
toolie
2121 posts in 2622 days
#1 posted 11-18-2012 08:09 PM
probably not. what it probably means is that at full load, the unit can draw over 20 amps. that would mean a 30A line would be the safest thing to install for it. but if you’re not going to overtax it, a 20A line will probably be ok. when i ran my unisaw and DC together on the same circuit, the combined FLA (full load amp) rating of the machines was 22A (16A unisaw and 6A dust collector). never tripped a dedicated 20A 220v breaker on 12/2 gauge wire. just my $.02.
View Bill White's profile
Bill White
4928 posts in 3954 days
#2 posted 11-18-2012 08:39 PM
IMHO, don’t bother with the HF unit.
I would have some real issues with the accuracy. There are some bargains at HF, but I don’t think that the “discker” is one of ‘em unless ya wanna just do some roughing.
If ya have a table saw, why not use a disc blade for better accuracy?
Bill
-- bill@magraphics.us
pantango
#3 posted 11-18-2012 09:34 PM
pantango
#4 posted 11-18-2012 09:37 PM
Toolie,
I was thinking of running a seperate line for my dust collector, I might as well add another for this sander. I have 8 open spots on my panel.
Its about a 20 ft run from one end to the other.
View RussellAP's profile
RussellAP
3104 posts in 2281 days
#5 posted 11-18-2012 10:08 PM
I don’t think HF ever sold anything capable of pulling 22 amps.
View dhazelton's profile
dhazelton
2766 posts in 2291 days
#6 posted 11-18-2012 10:19 PM
The website says 5.7 amps – gotta be a mistake on the label. How thick is the cord? If just extension cord thickness I’d believe the 5.7 number.
View exelectrician's profile
exelectrician
2327 posts in 2421 days
#7 posted 11-18-2012 11:47 PM
Lets do the simple math guys. 1.25 multiply by 746 equals 932 Watts. As we all know 932 Watts will draw 932 devide by the voltage which is 110 Volts – so the Maximum current at full load is 8.47 Amps. All induction motors draw two to four times the full load current for a brief moment at startup. Hence the (stupid) 22.7A printed on the name plate.
I had the Central Machinery 10” disc sander. the aluminium boss was a lousy fit on the shaft. I tried all of the usual gimmicks to “cure the problem” . I just took it to the dump.
-- Love thy neighbour as thyself
View patcollins's profile
patcollins
1685 posts in 2859 days
#8 posted 11-19-2012 01:26 AM
Contrary to popular belief there is nothing magic in a circuit breaker that will make it pop at the exact value on it.
After sustained use a 20A breaker can pop at 19A, or in short bursts you can get by with 22A on it. They are not high precision devices, just something “close”
pantango
#9 posted 11-19-2012 01:55 AM
exelectrician….seen the 10 in model right next to it. The 12 inch seem to spin free as the 10 inch model stopped right after you push it. The 12 inch seems heavy duty.
Well, maybe I’ll take the plunge on it
View crank49's profile
crank49
4030 posts in 2965 days
#10 posted 11-19-2012 01:58 AM
Any motor can draw 4 to 6 times its “rated” full load amps on startup.
Breakers handle this all the time.
Machines with large inertial loads (which take several seconds to reach operating speed) might require special breakers designed for this service, but it’s not normally a problem with most shop tools.
I have the HF 12” disk sander and it does say 22.7 amps start. Seems to be about in line with what a 5 or 6 amp motor would draw on startup. I just plug it into the same power strip my miter saw is plugged into and have it mounted next to the miter saw. Very handy to tweek the fit of some miters. Been using this setup for over a year without any problem. It’s a nice little sander IMHO.
I might have rather had the Rikon with its cast iron table and disk, but it’s well over $200; and for $200 I would have rather had the Ridgid oscillating belt/spindle sander. So, bottom line, I think the HF 12” disk, at $100, is a good tool at a good price and mine works just fine..
exelectrician
#11 posted 11-19-2012 07:32 AM
Pantango … grab the disc on the one you want to buy and try to pull it off…. if it moves just a little bit, try the next one untill you get one that has a disk that is tight on the shaft. You will find that the price difference between the 12” spare abrasive disks and the 10” is quite a lot. Also the hassle of changing a 12 is more than a 10.
And the surface speed of the outer edge of the 12” WILL BURN wood very easily. My 10” burned wood on the edge all the time. After I got my 8” I realized how much better it is to sand with a 8” than a 10” so yeah I really like my 8” because it is almost impossible to burn wood.
