Planer Question
Forum topic by RVroman posted 11-18-2012 04:53 PM 900 views 0 times favorited 8 replies Add to Favorites Watch
View RVroman's profile
RVroman
163 posts in 1993 days
11-18-2012 04:53 PM
Hi All,
I have a client who wants a cutting board like the one below. The dimensions they have requested are 9×13 x 1 1/4. It just so happens the walnut scrap I have left over from the one below is 13”, but it is 1 3/4” thick.
My thought, to avoid planer snipe, is to make the maple sides about 17” long so the overhang will be subject to the snipe, and can then be trimmed off. However, can anyone think of any issues with the rollers and blades starting on 2 1/2 inch wide, x 2 inch long “outside runners”, before the walnut in the center starts being cut?
-- Robert --- making toothpicks one 3x3x12 blank at a time!
8 replies so far
View Gshepherd's profile
Gshepherd
1727 posts in 2170 days
#1 posted 11-18-2012 04:57 PM
NONE, Go for it…... I have done the same thing and it works good…. In fact I am making some big panels for a kitchen table bench and I did longer outside runners for the same purpose.
-- What we do in life will Echo through Eternity........
View DIYaholic's profile
DIYaholic
19597 posts in 2644 days
#2 posted 11-18-2012 05:07 PM
That is a great question.
I’m new to planer use, so this is food for thought, should/when I run into a situation like this.
View Dusty56's profile
Dusty56
11819 posts in 3657 days
#3 posted 11-18-2012 05:21 PM
I do it all of the time…no issues so far : )
Your Maple is at least as thick as the Walnut , correct ?
RVroman
#4 posted 11-18-2012 05:30 PM
Thanks all. Dusty, Yes, I will make the maple the same thickness. Off to the shop! :-)
Dusty56
#5 posted 11-18-2012 05:45 PM
As long as it is thicker already , you’re all set : )
View jap's profile
jap
1251 posts in 2023 days
#6 posted 11-18-2012 06:39 PM
do it all the time
-- Joel
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3127 days
#7 posted 11-18-2012 07:34 PM
That’ll work. But I’d just push a longer scrap boards of the same thickness ahead and behind the cutting board.
-- jay, www.allaboutastro.com
117063 posts in 3546 days
#8 posted 11-18-2012 07:35 PM
Unless you have a serious problem with your planner you should be fine.
