Calling All Electricians
Forum topic by Brad posted 106 days ago 419 views 0 times favorited 19 replies Add to Favorites
View Brad's profile
67 posts in 310 days
106 days ago
Topic tags/keywords: tablesaw question tip
I just recently moved into a new rented house. The garage outlets are laid out horribly but since i don’t own the house i can’t redo the panel and add some much needed juice and accessibility. The circuit my TS runs on is a 15amp and the saw tends to trip the circuit if it bogs down in any wood at all.
I’d like some ideas on giving the shop more electrical accessibility and some suggestions on doing something with the TS circuit so it doesn’t trip all the time. I was thinking replacing the 15amp with a 20amp ideas???
- Brad
-- Great Coffee= 8oz strong coffee, 1tbsp brown sugar, 1tbsp 1/2&1/2, 1 heaping teaspoon mahoganny
View 3fingerpat's profile
3fingerpat
201 posts in 204 days
106 days ago
Brad,
Simply changing the breaker to a 20amp breaker is not the correct answer. If the guage wire that is currently connected to the 15amp does not support the 20amp breaker, then you are just asking for an electrical fire.
Recommend you get a qualified electrician to check out the circuit to see what is your best course of action.
View lew's profile
lew
1743 posts in 291 days
106 days ago
An electrician told me that a 15 amp breaker is usually wired to 14 gauge wire and a 20 amp fuse is wired to 12 gauge wire. If you replace the breaker, you should replace the wire- for safety.
How about adding a dedicated circuit for the saw. If there is not an open spot in the panel box, you can buy breakers that are “thinner” than the typical breaker. Two breakers fit into a space where one “normal” breaker fits. One of the new breakers would be for the original circuit and the other one could be wired as a dedicated to the saw.
I am not an electrician and I do not even play one on TV. Check it out with a licensed electrician before doing any work.
Lew
View LoneRider's profile
LoneRider
23 posts in 208 days
106 days ago
When I lived in an apartment I purchased a 12 gauge 50’ extension chord and plugged it into a kitchen outlet, ran it down the stairs forced it under the door into the garage and used it for my power tool of choice.
The only outlet in the garage was on the same circuit as my computer, stereo and TV, and let me tell ya, if you pop the breaker when Tivo is taping one of your girl friends favorite shows your in trouble.
cheers.
-- Tom - Canadian in N. Texas
View sIKE's profile
sIKE
605 posts in 290 days
106 days ago
Go to Home Depot and buy the book “Wiring Simplified” it is a tech reference and is based on the National Electrical Code and read the sections on wiring and service pannels so you have a good understanding of the topic then figure out what you can/would like to do and then get an electrician to come in and do it for you.
With that said if the service panel is located in the garage and has a one or two slots open, it should be simple to add a surface mounted single/double gang box with one/two dedicated 20 amp circuits located very near to the panel. When you move out you could chose to have him come back out and remove it for you, do it yourself (be wary there are mean beasties in them thar woods), or just leave it.
Hope this helps.
View BeechPilotBarry's profile
BeechPilotBarry
410 posts in 239 days
106 days ago
I like the idea of adding two 20A circuits, with the outlet boxes mounted to the wall next to the panel. If you offer to hire a qualified electrician to do it, you’ll have an easier sell with the property owner. If you’ve got the panel space, consider a 220v outlet, as well. Just leave it when you move.
While lots of us do this in our own homes and shops, no rental property owner in his/her right mind would give you permission to do it yourself. All nice, professional, and legal like,, by a local well-known electrical contractor? That may fly.
-- - Real men read directions
Dick, & Barb Cain
5383 posts in 836 days
105 days ago
The first thing I’d do is check to see what size wire you have in that circuit,
if its 12 gauge, change to a 20 amp breaker.
You also may be having a problem of low voltage, that could trip your breaker, so check the voltage.
Your service from the house to the garage might not have large enough wire size.
View snowdog's profile
snowdog
687 posts in 519 days
105 days ago
What dick said. There is a good chance you already have 12 gauge wire running.
View Bigbuck's profile
Bigbuck
1044 posts in 199 days
104 days ago
Just be carefull, In a rental property I would definately have a lic electricain do it. Where I live only a lic electrician can do any electrical work other than a few mundain items. If you burn that place down due to your electrical modifications you could be in some real hot water.
Other than that I would do like Tom said and run an extension cord from your laundry room wich should be on a beafier circuit.
-- Glenn, New Mexico
View Daves's profile
Daves
3 posts in 99 days
99 days ago
An extension cord should never be used on a table saw, most commerically availble cord are made from on 14 or 16 gauge wires. way too small to use on the table saw. The current draw is too large for them.
Better solution is to have a licenced Electrican add the 20 A circut, and place the outlet box close enough to your saw.
View motthunter's profile
motthunter
1234 posts in 335 days
99 days ago
may I recommend a fire extinguisher?
-- making sawdust....
View mski's profile
mski
271 posts in 516 days
99 days ago
motthunter has the FIRST recomendation I would take into consideration!
DO NOT mess with electrical wiring unless you know WHAT YOU ARE DOING!!!!!!!!!!!!!!!!!
BUT being the stubborn mule I am I have Tennesee TWO TWENTY!!! (sorry TN LJ’s)
I have two SEPARATE 110 V 15 A circuits in my garage, I wired up a box that plugs into each one of those circuits, Same thing as 220 BUT there are things you need to know about this 1/2 A&$ setup!!!!!!!
Again I SAY!!! DO NOT mess with electrical wiring unless you know WHAT YOU ARE DOING!!!!!!!!!!!!!!!!!
-- MARK IN BOB, So. CAL
View Brad's profile
99 days ago
Thanks for all the comments. i think for the time being i am going to just leave things alone. I was able to replace the lame incandescent bulbs in the ceiling with some 4’ florescent tubes which lit the shop up quite nice! But as for the TS guess I’m gonna have to just deal with it for now. And Mott i always keep a nice big fire extinguisher sitting in my garage especially since i work in the insurance industry and see people burn down their homes all the time.
View Kevin's profile
Kevin
284 posts in 494 days
99 days ago
MSKI, That is not the same as 220. You do not have the proper breaker set up when doing this. You will not have the proper line to line protection that you should have.
Please, no one else try this.
-- Kevin, Wichita, Kansas
View Dadoo's profile
Dadoo
1557 posts in 526 days
99 days ago
Here’s the problem…You don’t own the house.
The good thing is that it appears to be of fairly new construction, so your panel and wiring should be up to code. I’d try talking to the owner and offer to pay the electrician to add the new circuits to the garage. One of them should be on that center post. The lights should be on opposite breakers from the walls too. (I’m getting this info from your project postings). It’s gonna cost ya but a win/win situation for you both. The owner also needs to get some primer on that sheetrock soon as it will suck the moisture out of the air rather quickly.
Let us know how it turns out.
LoneRider
98 days ago
Kevin, excuse me if I expand on what you said, but I’ve got to add DON’T DO THAT!, really DON’T
That is not the worst thing I have ever heard of, but it is pretty close. If you ground out one of the wires, you will pop the one breaker, but you will have 120 volts going through the power tool. That could have interesting effects on your magnetic switch, and depending on the ground you could wind up running the motor on 120V, and that has the potential to over hear the motor and cause damage or fire. OR and possibly ever more interesting, if one of the breakers does go when the power tool is running, it is very possible, since the motor is running and the magnetic switch is engaged, it is very possible the motor will continue to run on the 120V in series with anything else on the the “dead” circuit. It gets even worse if you don’t have a magnetic switch, the motor “stops” but you leave the power switch turned on, the “dead” circuit will still have some juice in it.
Proper 220V circuits have twin circuit breakers that are tied together. To do anything else is only asking for something really bad to happen.
View mski's profile
mski
95 days ago
I did say “Same thing as 220 BUT there are things you need to know about this 1/2 A&$ setup!!!!!!!”
PS grounds tied together, I have popped them and they both go.
Again I say “Same thing as 220 BUT there are things you need to know about this 1/2 A&$ setup!!!!!!!”
View grumpycarp's profile
grumpycarp
208 posts in 282 days
95 days ago
There is so much bad information in this thread I couldn’t help but chime in .
Lone rider: if the supply side of the circuit is 14 g. then it doesn’t matter how burly the extension cord is, it’s still 14 g. in the wall where it will flame.
The rest of you who favor the red state rewire (a.k.a. Tennessee 220) I only hope you recycle enough trailer houses to buy yerself a welder or a hot tub and climb out while grounded and grab the fridge or something else besides the crack pipe. It will probobly not end well for you, although the gene pool will have cooler, less yellow water. . .
LoneRider
94 days ago
Grumpy,
Now I never suggested you put a 20A breaker/fuse on 14 gauge household wire, using a 10 or 12 gauge extension cord just ensures the lowest possible (practical) loss in the extension cord. Unless there is some strange power cord physics/EM theory I am not aware of, an extension cord can only limit current when placed in between a wall socket and electrical load :-)
cheers.
View EEngineer's profile
EEngineer
84 posts in 149 days
94 days ago
I am an electrical engineer – note the handle…
One vital piece of info that no one has asked for – what is the horsepower rating of your saw motor?
A 15 amp circuit on 120V will support a 1 1/2 HP motor under running conditions. According to most electrical codes, these should be wired with 14 AWG wire.
A 20 amp circuit on 120V will support a 2 HP motor under running conditions. According to most electrical codes, these should be wired with 12 AWG wire.
(I’ve posted all the math to support this on another forum here – no time to repeat it now)
One problem with motors is that they draw more current during start. So, even though the cicruit may be able to support your saw motor while running, the startup current may exceed the fuse rating and cause it to blow. This what time-delay (“slow-blow”) fuses were invented for. They will support more current than the rated current for a short time without blowing – specifically to allow motor start currents without tripping. Your solution may be as simple as replacing the fuse to your saw with a slow-blow type. Just replacing the 15 amp fuse with a 20 amp is not recommended unless you know you have 12 gauge wire running to the circuit.
Riunning the saw on an extension cord is not recommended – most all-purpose extension cords are wired with 18 AWG wire. This adds enough resistance to cause a voltage drop at the saw motor, especially diuring the higher surge currents darwn during startup. As the voltage drops the motor will draw even more current (take it as a given – too much theory for here). This can lead to a positive feedback condition (i.e. lower voltage → more current → even lower volatge → even more current → etc.) that I have seen lead to start currents of 5X or 6X more than the rated running current. The larger the wire diameter, the less the resistance. Wire diameter increases with decreasing AWG, so 18 AWG < 14 AWG < 12 AWG resistance.
Now, a personal anecdote…
I recently rebuilt an old Craftsman 10” table saw. It was originally supplied with a crappy little rocker switch mounted in a inconvenient location. I finally got around to rewiring it this summer and I used a manly power switch that was rated for more than my saw motor (3 HP vs 1 1/2). Lo and behold, when I powered it up, the lights in the garage no longer dimmed and the saw spun up to speed in about 1/2 the time it took with the old switch. The carppy little rocker switch was adding enough resistance in the circuit to radically increase the starting current. I am not suggesting that this is your problem, just that you have to consider the resistance in every leg of the connection from the power source to your saw.
Bookmark And Share This Page
