Flush mount locks
Forum topic by RussellAP posted 11-17-2012 07:41 PM 1485 views 0 times favorited 7 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3104 posts in 2520 days
11-17-2012 07:41 PM
Jocks, I found a place to get some accents for my furniture. I wanted to know if any of you know what a flush mount lock is. I have a chest I’d like to put one on, but I have no idea how it installs. I’d like to know before I buy one.
I need to know how you install this, I cant see one installed anywhere.
Thanks
7 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 3084 days
#1 posted 11-17-2012 10:07 PM
I suspect it’s like this except that a hook rotates up to a pin.
Does this help?
Kindly,
RussellAP
#2 posted 11-17-2012 10:49 PM
I really want to talk to someone who has worked with one to see how it’s installed.
View casual1carpenter's profile
casual1carpenter
354 posts in 2709 days
#3 posted 11-18-2012 12:34 AM
Russell, perhaps could you post a link to what style you are looking at? There is enough box builders that someone could perhaps help when they know what your looking at. I have a humidor build in my future sometime and I have looked at a few locks myself, but design is a ways off never mind the build.
View johnstoneb's profile
johnstoneb
3070 posts in 2406 days
#4 posted 11-18-2012 01:33 AM
I believe that lock is a drawerlock. To install it, you mortise oropen mortise the inside of the front of the drawer until the lock mechanism fits then cut a keyhole through the drawer front. Mount the decorative bezel then the strike plate is mounted in the desk front with another dado for the bolt to go into. If you want a lock for the hinged lid of the box you will need something similar with a hook that pivots over a pin or strike plate.
For a box you will need something similar to this
http://www.horton-brasses.com/store/locks/boxlock
http://www.horton-brasses.com/store/locks/halfmortise3#closed
Bruce
Boise, ID
-- Bruce, Boise, ID
RussellAP
#5 posted 11-18-2012 01:38 AM
I didn’t really want to mortise anything. I will if there is no other alternative.
View huff's profile
huff
2828 posts in 3519 days
#6 posted 11-18-2012 02:07 AM
Russell,
I believe they make that style lock in a mortise or non-mortise. The mortised type when mounted is flush with the back of the door or drawer front. The non-mortise would be simply mounted to the back of the door or drawer front. Either way, you have to drill for the key. You can usually drill a hole large enough for the top part of the key then use a rat tail file to longate the hole for the skeleton part of the key to fit. I’ve bought a number of locks from VanDykes restorations. http://www.vandykes.com/. You can order from them on-line, but you can ask for one of their catalogs. You’ll find a ton of stuff for making furniture, etc. and the catalog is a big help in explaining what each lock is.
-- John @ http://www.thehuffordfurnituregroup.com
RussellAP
#7 posted 11-18-2012 03:46 AM
Thanks Huff, I’m looking for places like that.
