mixing finishes question
Forum topic by Jay Nolet posted 11-17-2012 07:06 PM 991 views 0 times favorited 6 replies Add to Favorites Watch
View Jay Nolet's profile
Jay Nolet
75 posts in 2239 days
11-17-2012 07:06 PM
Topic tags/keywords: question finish
Hello all! I had a problem with getting a smooth finish from shellac, so after three coats I sanded smoothed and put acouple of coats of oil based poly. Looks like it came out fine. Is there anything I need to know about?
-- I think, therefore I think I am.
5174 posts in 2693 days
#1 posted 11-17-2012 07:41 PM
It pays to use dewaxed shellac under anything polyurethane. You may not have a problem if it was waxy shellac, but no sense in taking any risks. Polyurethane varnish doesn’t adhere as well as non-poly formulas, and things like the wax in shellac has been known to cause problems. If your shellac was waxy, nothing to do now but watch. But there’s also a chance you won’t see any issues.
View Bill White's profile
Bill White
5124 posts in 4160 days
#2 posted 11-17-2012 07:42 PM
I just hope ya used dewaxed shellac. If not, the poly will not adhere.
Bill
-- bill@magraphics.us
Jay Nolet
#3 posted 11-17-2012 11:27 PM
The poly is dry and hard. Might there be pealing at a later date?
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3358 days
#4 posted 11-18-2012 12:17 AM
Could be. It’s been tested both ways, some having issues with waxed shellac and others not. I have not. But over time, I might.
If you used something like the Zinsser Shellac from the can, that would be a 3# cut, meaning that there are 3 lbs. of shellac per gallon of denatured alcohol…a little thick to brush on. I’d dilute by 1/2 alcohol. That’ll give you a 2# cut which brushes on smooth and level.
Ideally, you’d use dewaxed shellac, like the Zinsser Sealcoat which is a 2# cut out of the can. Or, you can dewax it yourself by skimming the top off a can of shellac that’s been sitting still for a week or so…the wax usually settles at the bottom. The full shellac is more for when you want to use only shellac for the finish.
-- jay, www.allaboutastro.com
View Clint Searl's profile
Clint Searl
1533 posts in 2561 days
#5 posted 11-18-2012 12:39 AM
Don’t worry about it. It’s either OK or not; if it’s not, you’ll find out soon enough.
Jay Nolet
#6 posted 11-18-2012 03:18 AM
Thanks for the info. I found that I had an oily wood and it would’nt take poly. Being new to the hobby, I did know that I could use shellac on an oily wood, but I didn’t know about thinning. Now I know that I can thin, dewax or get it drunk on alcohol. I love this site.
