| Forum topic by Diggerjacks | posted 182 days ago | 343 views | 0 times favorited | 6 replies | ![]() |
182 days ago |
Hello What type of finishing did you prefer for acrylic pens ? And why ?? Thanks for your responses -- Diggerjack-France ---The only limit is the limit of the mind and the mind have no limit |
#1 posted 182 days ago |
WOW, I have never done a Acrylic Pen, but in inner thoughts tell me is there is no finish on them but sanding only to the finer grits. Micro Mesh. -- What we do in life will Echo through Eternity........ |
#2 posted 182 days ago |
Unless your blank has been cast with an additional material other than acrylic, just micromesh and polish. |
#3 posted 182 days ago |
I sand & polish acrylic blanks with micromesh then use Hut Ultra Gloss Pen Polish. PSI also makes a polish while some folks use Brasso and still others use car polish. Probably could stop after micromesh, but would feel guilty I guess. -- Bill |
#4 posted 182 days ago |
Mine is similar to wildwood..same as I do for my ca finish also. I ultimately go though mm through 12000 wet sanding and the polishy with hut ultra gloss and 1 last polish with novus 2 which was made for scratches on plexiglass. It is perfect every time. Make your final pass with a very sharp skew and start at 800 grit…saves lots of time and frustration. Bet of luck, Grub -- Science Teacher by Day, Wood Butcher by Night!! |
#5 posted 182 days ago |
I have gone to the automotive store and picked up Turtle Wax Scratch & Swirl Remover polish. Just a little on a rag after going to about 350 – 400 grit will totally clean up your pen and make it shine. I’ve used it on bottle stoppers and anything that I have used lacquer on. I then use mineral spirits to clean any residue off. For about $5 a bottle you can polish a lot of pens with it. When you really come down to it. The polish is just a grit suspended in a matrix. It works great, is quick to use, and cleans up easy for the price. -- look Ma! I still got all eleven of my fingers! - http://www.termitecrafts.com |
#6 posted 182 days ago |
I’ve wet-sanded with micro mesh similar to these, followed by Hut Ultra Gloss Pen Polish. http://www.woodcraft.com/product/2005233/10573/micromesh-pen-sanding-kit.aspx The micro mesh pads were a bit bigger, and they were 20 bux I think. Gives s a really great, glass-like finish. -- Roger from KY. Work/Play/Travel Safe. Kentuk55@bellsouth.net |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1523 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2737 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
