Table saw dado jig
Forum topic by Don Tikander posted 189 days ago 1032 views 0 times favorited 3 replies Add to Favorites Watch
View Don Tikander's profile
Don Tikander
75 posts in 468 days
189 days ago
Has anyone made a table saw dado jig? Most posts I find are for router dado jigs.
Thanks
-- Wood glue residue doesn't take a stain well.
3 replies so far
View lumberjoe's profile
lumberjoe
2401 posts in 420 days
#1 posted 188 days ago
I made a dado sled and a fence for rabbeting with a dado stack if that helps
http://lumberjocks.com/projects/68449
-- http://www.etsy.com/shop/KandJWoodCrafts
View jcwalleye's profile
jcwalleye
267 posts in 1245 days
#2 posted 188 days ago
Here’s a link to a cross-cut sled that accomodates different sized dado stacks with a replaceable insert. And you can use it as a regular crosscut sled.
I made one and it works really well. There are pretty good instructions on the web page.
Make your self a bunch of inserts and then you’ll have plenty for whatever sized stack you may use.
-- Trees, a wonderful gift --Joe--
View pintodeluxe's profile
pintodeluxe
1756 posts in 985 days
#3 posted 188 days ago
You don’t really need a jig or fixture for making dados on the tablesaw. It is already set up to make that type of cut with a dado blade.
The above crosscut sled is fine if you need to dado narrow stock. However I usually need to dado the sides of carcass pieces, so I just use the rip fence to guide the cut.
If it is a tall workpiece like a bookcase, then I use a router and straight edge guide.
Good luck.
