Outdoor Table. What to finish with?
Forum topic by ScrooLoose posted 184 days ago 600 views 1 time favorited 7 replies Add to Favorites Watch
View ScrooLoose's profile
ScrooLoose
3 posts in 184 days
184 days ago
Topic tags/keywords: question oak plane sander finishing traditional
Good morning, All!
A buddy and I have started woodworking on the weekends (well, for over a year now) and I have a question about how to finish a table I am making that will be outside in the Louisiana weather. We have a portable saw mill and have been getting a very large amount of lumber from a tank car facility that would otherwise be throwing it away. The lumber is generally rough cut to 10” x 10” for stacking between their steel shipments, and we were told the bulk of it was white oak. We’re not sure as it is very dense, heavy wood. We have been splitting this into rough 1.5” planks, letting it dry a few weeks (as most of it is “wet” in the middle), and then planing it and building our projects. I explain all that to ask this…
In projects past I have been using outdoor spar urethane to finish my projects, but have noticed some cracking and bubbling after a few months. He finishes most of his projects with a sanding sealer, and none are outside in the weather. I have a waterproofer with a clear additive I was debating on using.
What would you experienced guys suggest for a finish on this project which will stay outdoors year-round?
-- K & K Woodworking
7 replies so far
View CharlesNeil's profile
CharlesNeil
855 posts in 2037 days
#1 posted 183 days ago
First lets understand, your trying to finish green ( wet wood), a couple of weeks isnt getting the wood dry, at 1 1/2 thick you couldnt do that even in a kiln, so you have wet wood, and I am not aware of any finsh that will work with wet wood very well . White oak is an excellent exterior wood and will hold up with nothing on it, an ocassional washing with a 50/50 mix of bleach and water will renue it , you need to use stainless fastners, or you will have iron stains, ( black around screws and nails) , if this happens use some deck brightner, ( aka Oxalic acid) . The best product I am aware of that may help you is http://aquacoat.com/?page_id=114
821 posts in 660 days
#2 posted 183 days ago
Finishing any wet wood is doomed to fail. If you start drying it, I can recommend untinted paint. This would be the #4 (or #5 in Olympic) oil exterior base. It will dry to look much like varnish, with the advantage being it is outdoor paint, and has UV inhibitors in it. You can read more about it here, this is the article that put me onto using it.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
View weekendwoodworker's profile
weekendwoodworker
11 posts in 196 days
#3 posted 183 days ago
What these guys are saying is true. You will have a hard time getting green wood to last and look good outdoors. When you are working with dry wood outdoors, so far I have found nothing better than boiled linseed oil. I have a picnic table built by my dad in the 60’s out of untreated pine that is still around today. You have to use boiled linseed oil as unboiled linseed oil never really sets up and is always oily to the touch. And every couple of years you have to reapply a coat, but 50 years outside from untreated pine is pretty good. I don’t know any of the newer finishes that have that kind of track record.
View Clint Searl's profile
Clint Searl
846 posts in 528 days
#4 posted 183 days ago
Don’t use linseed oil, boiled or not. It’ll turn moldy black on oak. Been there.
-- Clint Searl.............We deserve what we tolerate
View BHolcombe's profile
BHolcombe
40 posts in 242 days
#5 posted 182 days ago
Dry the board first, you’re putting the cart before the hoarse. Outdoor tables are difficult enough without the added factor of drying the wood after the project is built.
I built an outdoor table for myself in Padauk, finished it in waterlox marine finish and both the wood and table are doing well outside.
ScrooLoose
3 posts in 184 days
#6 posted 181 days ago
Thank you everyone for the advice!
I knew it was “green” when we started cutting it, but the wood is so beautiful we just wanted to start making things right away.
I will take all the advice to heart and try to store the wood away until it can dry out on it’s own, which I know is some time away from now. I can say that a few tables have already been built with this wood for indoor use at my buddy’s house, and a simple sanding sealer used on it and two months in they are OK. (I know, 2 months is no time at all.) :)
Thanks again everyone!
View Joseph Jossem's profile
Joseph Jossem
162 posts in 435 days
#7 posted 181 days ago
Sikkens is the best out door product wont crack over time.
