Would you spend $100 on this jointer?
Forum topic by BinghamtonEd posted 11-15-2012 07:30 PM 2752 views 0 times favorited 11 replies Add to Favorites Watch
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2370 days
11-15-2012 07:30 PM
I don’t currently have a jointer. I do, however, have a 3-month old, so a new Grizzly or the likes is not in the budget. Anyone heard of Industriline? I see this one is on CL for $100. What do you think? Besides checking the blades for damage, and making sure it runs, and maybe putting a board through it, what else would one check?
11 replies so far
View chrisstef's profile
chrisstef
17387 posts in 3007 days
#1 posted 11-15-2012 07:33 PM
It certainly looks liek a delta clone 37-220 would be the delta model. Besides checking the blades, and hearing it run make sure you can remove the screws that hold the blade in, and if you have a good long straight edge make sure the tables are flat. A table way out of whack is a deal breaker. Unplug it and spin the cutter head by hand listening to the bearings. Theyre cheap enough but no harm in checkin it out.
View jbswearingen's profile
jbswearingen
108 posts in 2160 days
#2 posted 11-15-2012 07:36 PM
I’ve never heard of the brand. Having said that, if it’ll work for you, then great. Yes, check as you have suggested. Take a known straight edge and test the beds for flatness and parallel.
But, instead of buying, how about building one? Yes, it’ll cost more, but you can do it in steps. I’m in the process of building this one:
http://woodgears.ca/jointer/homemade.html
Instead of doing what the designer did—strip a portable planer for its cutter head and motor—I’m going to use a 15” planer cutter head a friend doesn’t need anymore; he swapped it for a Byrd style cutter head. I’ll need to purchase a 1.5-2hp motor, but those are fairly cheap used.
My Jet 6” jointer works a charm, but it’s too damn narrow!
I’m figuring $300 total on the project.
-- Semper fi, Brad
View crank49's profile
crank49
4030 posts in 2971 days
#3 posted 11-15-2012 07:40 PM
That looks like the HF jointer.
As long as you can get blades and stuff for it I think it would be great.
View Planeman40's profile
Planeman40
1176 posts in 2761 days
#4 posted 11-15-2012 09:29 PM
Its obviously a copy of the Delta 6” jointer, most likely Chinese. Looks good in the photo, doesn’t show a blade guard which can probably be bought at Harbor Freight as a replacement part for the HF jointer. A blade guard can also easily be made or located as Delta jointers are common. The 6” blades are easy to come by and are about $15 for a set of three in high speed steel. I buy mine on Amazon. I have a Delta 6” jointer so I know this. The rust can be removed using a wire brush wheel in an electric drill and some fine wet-or-dry sandpaper with oil or WD-40 as a polishing lubricant. All of this and some gray enamel paint and the thing will look like new.
I would look carefully at the quality of castings and assembly. I would also put a long straightedge across the infeed and outfeed tables when they are in line with each other to see if the tops are parallel with each other. If all is well, go for it!
Planeman
chrisstef
#5 posted 11-15-2012 09:32 PM
Here’s the delta for comparison. Not the best pic but you can see how the fences and hand cranks are identical. Id pull the trigger on it Ed. Good Luck and keep us posted.
Beginningwoodworker
13345 posts in 3673 days
#6 posted 11-15-2012 09:37 PM
Could be a Harbor Feight model, I would pass.
View PurpLev's profile
PurpLev
8535 posts in 3649 days
#7 posted 11-15-2012 10:03 PM
if the table is straight (check it with a long quality straight edge) and the table moves freely up/down for thickness, , the fence locks solid, and the motor runs quietly – then it’s worth the $100.
a jointer is one of the more simple machines out there, as long as the above is met, there really isn’t much more to it.
View GlennsGrandson's profile
GlennsGrandson
442 posts in 2310 days
#8 posted 11-15-2012 10:10 PM
I bought this one for $100
Now it’s like this
I’d do it again. I ended up being about $250 into when it was all said and done. Here's my blog about it.
-- Grant - N Dakota
117095 posts in 3578 days
#9 posted 11-15-2012 10:10 PM
To answer you question yes I would if it worked well and had a flat bed and I needed a low cost jointer.
Most $100 jointers I’ve seen are 4” and have 3’ beds. If you have more funds to work with I think would go for a new Grizzly or a used Powermatic.
View Tennessee's profile
Tennessee
2873 posts in 2515 days
#10 posted 11-15-2012 10:21 PM
After everything listed to check, it looks like a winner to me. You can always resell it for the same money, me thinks…
View LiePie's profile
LiePie
7 posts in 3008 days
#11 posted 11-16-2012 01:36 AM
I would do the checks mention by previous posters. If everything checked out I would spend the $100. I always wonder where these buys are in my part of the Country.
