How do you hone in between sharpening sessions?
Forum topic by live4ever posted 216 days ago 1084 views 0 times favorited 40 replies Add to Favorites Watch
View live4ever's profile
live4ever
980 posts in 1207 days
216 days ago
Topic tags/keywords: sharpening waterstone green compound honing
Nothing like a freshly sharpened plane iron. My plane irons are all A2, but I find they lose their super sharp edge pretty quickly and need a touch-up.
My general sharpening strategy consists of 1000, 6000 waterstones followed by green compound on MDF. Therefore, the quick touch-up for me is on the MDF with green compound.
In order to make the touch-up as painless as possible, I’d prefer not to have to chuck the blade in the honing guide because I’m not likely to touch-up if I have to spend time getting out the guide, setting up, yadda yadda. But it’s almost impossible (for me) to touch-up a micro-bevel freehand. Perhaps I need to re-think my initial sharpening strategy and use a larger secondary bevel instead of a tiny one?
So how do you guys “touch-up” quickly in the middle of a planing session? Free-hand or with a guide?
40 replies so far
View MJCD's profile
MJCD
349 posts in 568 days
#1 posted 216 days ago
With a guide (Veritas) and 2000-grit wet sandpaper; as my sharpening skills are in their infancy – I’ve been told by several LJ members do it freehand.
MJCD
-- Lead By Example; Make a Difference
View bobasaurus's profile
bobasaurus
697 posts in 1381 days
#2 posted 216 days ago
I’m trying to change most of my sharpening technique to freehand for speed and easy setup. It makes for slightly convex bevels, but they still cut just as well. I touch-up freehand the same way I do a full sharpening, but starting at either the finest stone or medium then finest. I haven’t used a strop yet, but I plan on making one soon.
live4ever
#3 posted 216 days ago
MJCD, do you use a microbevel? They sure are easy to create with the Veritas guide (love that thing…I’d be lost without it).
live4ever
#4 posted 216 days ago
bobasauras – at least you’re on the freehand track…those of us dependent on guides get screwed when it comes to touch-up!
View HorizontalMike's profile
HorizontalMike
5593 posts in 1111 days
#5 posted 216 days ago
I am finding more and more that I will use the “contractor’s paper” I have taped down on my workbench, to burnish my chisels and other blades while I am busy. Not perfect, but it surely does a good job, IMO.
live4ever
#6 posted 216 days ago
Mike – contractor’s paper – is that like kraft paper?
Smitty_Cabinetshop
6592 posts in 816 days
#7 posted 216 days ago
Strop with green compound works very well, ala Paul Sellers’ 30 strokes.
-- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive
View StumpyNubs's profile
StumpyNubs
5111 posts in 998 days
#8 posted 216 days ago
I use a Worksharp 3000 with MDF discs covered with polishing compounds. To touch up the blade on a chisel I just stick it in the slot the machine has built in. I keep it set to the microbevel angle, so is needs no adjustments for a quick touch up. No jig required. For hand planes I usually put off honing until I absolutely have to. Then I use a jig on the top of the WS (I built a platform on an episode of BCWW). Since I am going to the trouble to take it out of the plane and all, putting it in a jig is not that much more work.
-- It's the best woodworking show since the invention of wood... New episodes Wednesdays at: http://www.stumpynubs.com
View TechRedneck's profile
TechRedneck
648 posts in 1054 days
#9 posted 216 days ago
It took a little effort at first, but I watched Paul Sellers videos on hand sharpening.
Touch ups for me now consist of 15 seconds on an 8000 grit waterstone (kept wet in a tub) then 30 strokes on a strop with green compound. Whole process from iron removal to replacement is 5 min tops. Chisels are quicker.
Once the backs are flat and polished, I never touch them again except one swipe on the strop to remove the micro burr.
I also made a dedicated sharpening station that keeps things organized. I refuse to use tools that are not sharp.
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
StumpyNubs
#10 posted 216 days ago
TechRedneck- I heard that leaving your waterstones in the tub is bad for them. I don’t use waterstones, but I wondered about that…
live4ever
#11 posted 216 days ago
TechRedneck – that’s exactly what I’m going for on touch-ups. Only my problem is that I’m terrible at freehanding microbevels. It does more harm than good to touch them up. Are you using microbevels/freehanding them?
TechRedneck
#12 posted 216 days ago
Stumps
No issues so far, I rinse the stone and change its bath water every month or so but thats it. It is a stone that needs to be wet. Now my shop is heated, if it were not and prone to freezing, that’s another issue.
View paratrooper34's profile
paratrooper34
699 posts in 1149 days
#13 posted 216 days ago
I use a leather disc on a WS 3000. Quick and easy to get a dulling blade freshened up. Since I use waterstones as my sharpening system, the WS 3000 has a primary function for the touch-ups.
I second keeping waterstones in water all the time. Been doing it for a few years now with no effect whatsoever. I keep a little bleach in there to keep the water from getting funky and they do just fine.
-- Mike
View thebigvise's profile
thebigvise
178 posts in 1098 days
#14 posted 216 days ago
I admire my freehand colleagues, but I love the precision of my Veritas Mk II guide. Yes, it definitely takes longer…
-- Paul, Clinton, NC
View MJCD's profile
MJCD
#15 posted 216 days ago
I do use the micro-bevel; and I don’t touch the backs – probably once every two months I’ll polish the backs, just to ensure no gummy build-up. And I do keep a wet-sandpaper handy during all project builds – One of TechRednecks many sage practices.
Since I use a consistent angle (probably not the best practice), I don’t need to use the Veritas reference jig – I just pop the blade into the honing guide, preset for micro-bevel; quick stokes on the wet paper, and I’m ready to go.
I’m not as finicky as most others on the amount of time spent touching-up during a project build – I’ve had what most would call a stressful career; I’m not going to ruin any years I have remaining worried about how much time I spend sharpening tools. If the blade needs a quick honing then hone the blade!
By the way, there are Optimists, Pessimists, and Realists; and depending on the circumstances the Realist is always one of the other two.
MJCD
showing 1 through 15 of 40 replies
