A Technical Question on the Hammer N4400 Bandsaw
Forum topic by MJCD posted 11-14-2012 09:34 PM 4263 views 1 time favorited 5 replies Add to Favorites Watch
View MJCD's profile
MJCD
514 posts in 2244 days
11-14-2012 09:34 PM
Topic tags/keywords: hammer n4400 bandsaw blades bandsaw guides
First, an apology to the thousands of LJ member for whom this question seem an obscure request …
I’ll be the new owner of an N4400, this January. I’ve read conflicting (to put it mildly) reports on the following:
Blade Guides – Felder seems to have irritated many N4400 owners with their choice of guides; and I’m wondering if it is a foregone conclusion that I’ll need to upgrade to Carter guides?
Blade Width – simple question – can the N4400 properly tension a 1” Lenox/Starrett blade; or am I limited to 3/4”?
Blade Choice – this is like asking knowledgeable professions their favorite brew – from the ridiculous to the sublime. Let’s say that I’m narrowing my selection to Timberwolf, Lenox, and Starrett; knowing that I’m offending many faithful.
Most preferred add-on: my choice is extension tables for ripping; or perhaps an upgraded fence.
Again, LJ is a great Forum, and I welcome informed responses.
MJCD
-- Lead By Example; Make a Difference
5 replies so far
View Surfside's profile
Surfside
3389 posts in 2047 days
#1 posted 11-14-2012 10:20 PM
Blade choice , I have Haltbar 101 series blade. It’s working with me along nicely. Try searching sawblade.com .
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View Jorge G.'s profile
Jorge G.
1537 posts in 2348 days
#2 posted 11-14-2012 10:29 PM
I have the same BS, yes you will need the Carter saw guides, the ones Felder uses suck big time. I have not upgraded mine, but I cuss them every time I use it.
The BS has a scale for up to 1 3/8” blade tension, I have used 1” blades on it with no trouble.
Blade choice is up to you, I can only get cheap blades here in Mexico.
The fence is pretty good, between the two I would go with the extension tables, but to be honest you can make them yourself, no need to pay Felder for a cheap piece of aluminum when you can make them from wood with an end support.
-- To surrender a dream leaves life as it is — and not as it could be.
View MJCD's profile
MJCD
#3 posted 11-14-2012 10:58 PM
Surfside & Jorge:
Thank you for the prompt response – I’ve been on-my-own it seems getting these questions answered – the Felder Owner’s Group has not been responsive.
Thanks for the recommendations, as well – they make a lot of sense. I had Carter Guides on my Delta 14”, and they transformed the saw into a respectable machine. I’ll order the upgrades now, and save myself the interim hassle.
Do Take Care.
MJCD
Surfside
#4 posted 11-15-2012 02:46 PM
You are welcome MJCD. Goodluck to you !:)
View John Ormsby's profile
John Ormsby
1283 posts in 3610 days
#5 posted 11-15-2012 03:19 PM
Have you looked into ceramic guides? I installed them on my 24” bandsaw and they really made a difference. It runs quieter and the blades never heat up.
-- Oldworld, Fair Oaks, Ca
