| Forum topic by yellowtruck75 | posted 188 days ago | 332 views | 0 times favorited | 4 replies | ![]() |
188 days ago |
I am trying to darken up the stain on a cherry wine rack that I am working on right now. The first two coats are a gel stain, the first coat was blotchy so I lightly sanded it off and added a second gel stain coat. I would like to put a final coat on but avoid the gel stain if possible. If the stain is darker than the previous coats will the two stains bond together or will it not finish correctly? Thanks |
#1 posted 188 days ago |
When you brush it on top, the solvent in the stain will take up some of the previous gel stain coat…assuming they are both oil-based with mineral spirits for a solvent. A few approaches… 1.) Use a water-based stain or water/alcohol dye on top. If it were me, I would seal with shellac and then figure a way to spray the stain…perhaps with an aerosol with the color you favor. After that, spray with one more coat of shellac and then brush on your choice of film finish. When sealing with shellac, it doesn’t take much…just a uniform thin coat that will dry in like 15 minutes. -- jay, www.allaboutastro.com |
#2 posted 188 days ago |
BTW, one of the most frustrating aspects of finishing is taking a pigment stain, like that gel stain, and wiping or brushing on anything on top that uses the same solvent…whether this is another stain or a film coat doesn’t matter. Shellac is wonderful for sealing between each transition. Test everything on a practice board first. Try it without the shellac and watch the rag pull up the dried undercoat, smearing it all around. It’s not pretty. :) -- jay, www.allaboutastro.com |
#3 posted 188 days ago |
give it a shot … some of my best work is layer over layers of stain and finish. -- keeping myself entertained |
#4 posted 188 days ago |
Yeah, something like a wine rack could be artsy-fartsied up a little bit. Definitely experiment. But if this were a cherry table or something, you’d want it uniform and pretty. Of course, with a cherry table, it would have been a crime to put gel stain on it. -- jay, www.allaboutastro.com |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1532 |
3547 |
15776 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2840 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
