router variable speed stuck at slowest speed
Forum topic by justbob posted 11-14-2012 03:26 AM 4858 views 0 times favorited 13 replies Add to Favorites Watch
View justbob's profile
justbob
16 posts in 2125 days
11-14-2012 03:26 AM
I have a Porter Cable 890 router the variable speed controller has stopped working and it only runs at the slowest speed. The replacement part costs $100 I only paid $200 for the whole package. Can I buy an after market speed controller to get it to run at top speed? I’m guessing no so can I safely bypass the one in the router if so I need to know how to do it. In other word which wires need to go where.
13 replies so far
View pintodeluxe's profile
pintodeluxe
5706 posts in 2840 days
#1 posted 11-14-2012 04:33 AM
It sounds like the armature assembly has failed. Usually it fails at full speed, but not always.
I wouldn’t guess a secondary speed controller would help. This is a known problem with the 890 model.
justbob
#2 posted 11-14-2012 01:01 PM
One thing I forgot to mention was that it will randomly go from low speed to high speed run for a few minutes and then go back to low speed.
View bondogaposis's profile
bondogaposis
4767 posts in 2378 days
#3 posted 11-14-2012 01:15 PM
I’d go for a new router, stuff wears out.
-- Bondo Gaposis
View EEngineer's profile
EEngineer
1103 posts in 3640 days
#4 posted 11-14-2012 01:33 PM
I don’t know whether I would blame the armature. To me this sounds like a speed controller failure. It it is the speed controller, there might be a simple solution.
A while back (thread here), I answered some questions about soft-start and a variable speed controller for a motor. His solution was to bypass the soft-start and add an external variable speed controller.
If you want to save the router and some money, your solution might be the same. You can pick up an external variable speed controller for routers for ~$20. If you bypass the speed controller in the router (the thread I mentioned above has a description of what he did to bypass the soft-start circuit), then you can use an external speed controller. This is also a quick way to test whether the speed controller or the armature is the problem. Bypassing the speed controller won’t hurt the router – it will just run at full speed anytime you switch it on. Routers worked like this for years before they starting adding speed control.
View wunderaa's profile
wunderaa
248 posts in 2229 days
#5 posted 11-14-2012 03:28 PM
If you’re adventurous, you can try a few things.
Potential Failure Causes
- Dust Build Up Inside Top of Assembly Interfering with Feedback (Unlikely, but easy to check)
- Broken Speed Feedback Magnet
- Bad Speed Control Board
Take apart the top of the router revealing the top of the motor shaft and electronics (you may have another layer to remove below the control board before you get to the top of the shaft). Blow out the assembly with compressed air and see if that does the trick. Again, unlikely.
When you open the top of the assembly, you’ll see the control board and the top of the motor assembly. If you look at the top of the motor shaft you should see a magnet mounted to the shaft. Most likely, this magnet has broken. It’s this magnet that, when spinning, generates a current in a coil of wire that surrounds it (Faraday’s Law, anybody!?). That current is proportional to the shaft speed. That current is fed into the controller and utilized in a feedback loop. I’m guessing that they may have designed the unit to fail such that the tool can still be used, but we can find out for sure soon.
If the magnet is broken, you can either find a replacement (try www.ereplacementparts.com), or go about converting your router into a still-useful single-speed unit with an external speed control.
What I would try from there is to remove the magnet completely from the shaft. Put the unit back together and see if it still works. If it goes up to full speed, then they have engineered the unit to fail at full speed and you should be good to go. If it’s dead or runs at low speed, we can move on to the next step.
At this point, you can either junk the unit or grab a soldering iron and some shrink tubing. The fix from here-on is to bypass the control circuitry completely. In the safest manner possible, connect the two wires leading from the on/off switch to the two wires going to the brushes, disconnecting all power wires from the control board (although there may only be one power wire routed through the board). If you sent a picture of the control board itself, I may be able to tell you what two pins to solder together on the board to effectively accomplish the same thing, but that’s about the best I’ve got without seeing the unit. That may be as simple as wiring two pins from the triac together, but can’t tell without a picture.
Assuming that goes well, you should be able to run the unit at full speed. You can then purchase an external speed control unit from Rockler or elsewhere to control speed if needed.
Hopefully this helps or at least gets you headed in the right direction.
View HorizontalMike's profile
HorizontalMike
7758 posts in 2941 days
#6 posted 11-14-2012 04:19 PM
”...Blow out the assembly with compressed air and see if that does the trick….”
Well worth the effort to use compressed air. This worked on my old Dremel tool, kinda like a mini-me router ;-)
404 - Not Found
2544 posts in 2996 days
#7 posted 11-14-2012 05:53 PM
^ Worth checking – I have experienced this on a Dewalt DW621 Router, however, it was stuck on full speed.
View NiteWalker's profile
NiteWalker
2737 posts in 2603 days
#8 posted 11-14-2012 11:04 PM
Exactly; if the magnet broke the motor would be stuck on full speed, as is the case with both of my dewalt 618’s.
justbob
#9 posted 11-15-2012 01:08 AM
thanks for the input I’ll try all of the suggestions tomorrow
wunderaa
#10 posted 11-15-2012 03:46 PM
curious to hear how this turns out!
justbob
#11 posted 11-20-2012 10:14 PM
just completed the bypass router runs at top speed since that is how I use it almost exclusively its not a big deal, if i ever need to raise a panel i can go buy an aftermarket speed control. the only feature I kind of miss is the soft start.
wunderaa
#12 posted 11-21-2012 04:58 AM
Awesome!
View Howie's profile
Howie
2656 posts in 2950 days
#13 posted 11-21-2012 01:03 PM
I’ve been having the same problem with my Makita 1101. Been a good piece of equipment.Thanks to some of these suggestions I’m going to try and salvage it rather than buy a new one.
-- Life is good.
