| Forum topic by Brian Strothcamp | posted 190 days ago | 888 views | 0 times favorited | 35 replies | ![]() |
190 days ago |
Im wanting to recreate this frame out of Jatoba and Maple… I cant think of a single safe way to cut this on a power tool. Note the 45 on each end. Router maybe… still must hand tool the 45 I dont want just an inlay… must go all the way through and could be up to 8” in length Im stumped
35 replies so far
#1 posted 190 days ago |
band saw would be my first guess…how wide is that spline? -- It's made of wood. Real sturdy.--Chubbs Peterson |
#2 posted 190 days ago |
If I had to do it, I’d put that spline in there before the wood was milled to final size and shape. Then, when you cut the angle on the frame, and the 45 for the corners, it would all line up. I hope that makes sence I can see it in my head but sometimes the fingers don’t do a good job of explaining -- Gary, DeKalb Texas only 4 miles from the mill |
#3 posted 190 days ago |
You could rip the kerf for the spline on the table saw, and shape the end with a chisel. Edit: by end I mean the rounded part the table table saw will leave behind. It would be mitered after the spline is glued in, dimensioned and routed for the rabbit. |
#4 posted 190 days ago |
Width of the spline will vary… the only part i dont understand is cutting the void for the spline. Shane, bandsaw would be too rough i think. I realy dont want to hand tool it either (quick xmas gifts ha) |
#5 posted 190 days ago |
Kerf cut on table saw first then add spline and then miter. |
#6 posted 190 days ago |
Custom ground blade (CA or DA) with 45 degree top bevel. Cut the slot, clean up small amount of arc, and cut spline to fit. -- Nothing to it, but to do it ... |
#7 posted 190 days ago |
Lay it out Practice on scrap first, second, etc. Good luck, you can do it. |
#8 posted 190 days ago |
blackcherry some people just dont get it -- "Good artists borrow, great artists steal”…..Picasso |
#9 posted 190 days ago |
How thick is the dark wood at it’s thickest point? I was thinking you could use half inch stock and simply angle it for the deep 45, then just treat it like molding at the corners. Rout out the maple slot. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#10 posted 190 days ago |
If you dont want the inlay, you’ll have to take the Jatoba and rip the lengths out, cut it where you want the maple and then glue the maple in. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#11 posted 189 days ago |
I thought I had it, and type up a detailed explanation. |
#12 posted 189 days ago |
Kerf cut on table saw, clean up and make 45 with small jeweler’s file. Just my opinion. Or maybe something with lasers. That’d be cool. -- - The mightiest oak in the forest is just a little nut that held its ground. |
#13 posted 189 days ago |
trexco That’s the best concept i could think of as well If the spline were short enough you could cut on end but limited to blade height (also thought this would be too dangerous) this would eliminate the arc. You may not need to clean up the arc though if the spline were cut at the proper angle to just touch the front and back corners, this would leave a void the shape of the arc. And final milling would expose this gap. Just dont want to order a funky blade grind unless I have too, but would bite the bullet if absolutely necessary. |
#14 posted 189 days ago |
ripped on the TS – PRIOR to cutting the miter on the frame using a stopped cut (cut to line. stop TS, remove part, rinse and repeat) the 45 at the end of the accent strip should be created and cleaned up with a narrow chisel. -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#15 posted 189 days ago |
A jig like this combined with a custom ground blade in your TS would do it. Not cheaply, but fast an high production capability. Or, like this and hand make the little 45 in the corner with a fret saw or perhaps a custom ground chisel. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3550 |
15785 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
