waterbourne finish ???
Forum topic by Howie posted 11-14-2012 12:24 AM 894 views 0 times favorited 9 replies Add to Favorites Watch
View Howie's profile
Howie
2656 posts in 2916 days
11-14-2012 12:24 AM
Does the waterbourne varnish 2nd coat “melt into” the first coat like the oil based poly?
-- Life is good.
9 replies so far
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3151 days
#1 posted 11-14-2012 12:36 AM
No…and neither does oil-based poly.
-- jay, www.allaboutastro.com
View Joe Lyddon's profile
Joe Lyddon
10091 posts in 4045 days
#2 posted 11-14-2012 12:56 AM
Cosmicsniper +2
A light sanding between coats… is required.
117083 posts in 3570 days
#3 posted 11-14-2012 01:21 AM
Yes and no . Water base with allow a second,third,etc as long as it;s done in the open time the manufacturer states.
After drying beyond that it will still cling to a previous coat but not anywhere nearly as well.
View live4ever's profile
live4ever
983 posts in 3003 days
#4 posted 11-14-2012 02:25 AM
It will if you are applying the second coat within a certain amount of time (sometimes called “burn-in time”). For the WB finishes I use it’s around 24 hours. After the first coat cures, then no, and you’d need to scuff-sand like Joe said to get good adhesion between coats.
View shampeon's profile
shampeon
1775 posts in 2176 days
#5 posted 11-14-2012 05:30 AM
Target Coatings EM6000 does in fact melt into the previous layer. Poly doesn’t, but nitrocellulose lacquer does.
live4ever
#6 posted 11-14-2012 09:48 AM
A bit of clarification on EM6000. It’s advertised as having infinite burn-in time but in reality even Target Coatings recommends a little scuff sand if it’s over 24h for best results.
Cosmicsniper
#7 posted 11-14-2012 01:07 PM
Howie: The confusing part of your question is the words “melt into”. That is more descriptive of evaporative finishes like shellac and lacquer, both of which react with its solvent once reintroduced to it. Put down a coat of lacquer, let it dry, and the solvent in the next coat will reactivate the first layer and they’ll melt together.
Varnishes, like poly, do not act this way. They are “reactive finishes,” meaning that they change through chemical reaction while drying. During this “curing,” once the solvent is dried off, they can no longer be reactivated by the solvent in subsequent coats. So they harden in layers relying on a mechanical adhesion to each other. Thus, you give it “some teeth” by scuff sanding between layers.
Cosmicsniper
#8 posted 11-14-2012 01:26 PM
Hmm, okay, in an attempt to be clear about certain things, I’ve learned something myself. Water-borne finishes apparently do burn-into a previous coats by reactivation with its solvent, in that case glycol ether. I had recklessly categorized them as varnishes. This is again an example where product-labeling is deceptive…they are often called “varnish,” “poly,” and even “lacquer.” In truth, they are acrylics, with some resins blended in for hardness.
However, part of what I said is correct in that by comparison to true evaporative finishes, they have a smaller percentage of solvent, so there isn’t as much of a “melting into” with the water-borne stuff. Chiefly, it means that you don’t need a mechanical “tooth” to adhere coats, so no sanding. This probably explains why I haven’t noticed this in action so much when I spray such finishes. I usually handle them like shellac or lacquer without sanding in between. Now I know why I like them so much.
Thanks for sparking the educational opportunity!
Nevertheless, the original post does contain an error…oil-based poly most certainly does NOT “melt in.”
Howie
#9 posted 11-14-2012 01:49 PM
Thanks to all for the clarifications. As usual ,I can always find an answer at LJ’s.
I used to use the poly but am starting to use the waterbourne. I figure I might as well get used to it, won’t be long til that’s about all you get.
-- Life is good.
