Clamp Time
Forum topic by bondogaposis posted 186 days ago 426 views 0 times favorited 9 replies Add to Favorites Watch
View bondogaposis's profile
bondogaposis
1237 posts in 517 days
186 days ago
Topic tags/keywords: question clamp joining
How long to leave clamps on when working w/ Titebond II as a minimum. Normally I try to glue up in the evening and un-clamp the next morning but I’m in a bit of a hurry to pull my clamps and move on to the next glue up. Is 2 hours sufficient?
-- Bondo Gaposis
9 replies so far
View RussellAP's profile
RussellAP
2394 posts in 452 days
#1 posted 186 days ago
Depends on the torque of the piece or that the piece has on it, but I’d say one hour is minimum to get things to stay put with TBII.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
View derosa's profile
derosa
1467 posts in 1001 days
#2 posted 186 days ago
If you didn’t joint well and are using the clamps to help tighten the joint then leave them till tomorrow, if the clamps are just to align the wood then 1hr.
-- --Rev. Russ in NY-- A posse ad esse
View Dusty56's profile
Dusty56
10496 posts in 1854 days
#3 posted 186 days ago
Don’t know what you’re gluing , but my cutting boards range from 5/8” to 1.5” thick and an hour is usually sufficient for them. Haven’t had a joint failure to date : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
View Monte Pittman's profile
Monte Pittman
7035 posts in 504 days
#4 posted 186 days ago
It depends also fo me if it a tray divider or box mitre joints. Two hours will probably hold. I try to leave bigger joints 24 hours. Just me.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
86947 posts in 1743 days
#5 posted 186 days ago
I guess it’s going to depend on how warm it is in your shop Bondo and what your gluing. large panels I like to leave in overnight but things without a lot of stress on them 2-3 hrs in 65 degrees.
View ShaneA's profile
ShaneA
3956 posts in 764 days
#6 posted 186 days ago
2 hrs should be fine for most joints, given a decent temp, long grain to long grain joint. You may not want to run the joint through a planer or jointer for a while longer.
View Gshepherd's profile
Gshepherd
1363 posts in 367 days
#7 posted 186 days ago
This past week I glued up over 1200 lf, 6 in wide poplar for base moulding, 30 min rotation, took close to 10 hrs to get it all glued up 30 min through the moulder. no glue failures….
-- What we do in life will Echo through Eternity........
bondogaposis
#8 posted 186 days ago
I’m gluing some smaller panels 12”x32”, 2 boards in each panel, species is poplar. Shop temp 60°, but will drop to 50° overnight.
-- Bondo Gaposis
View JesseTutt's profile
JesseTutt
707 posts in 276 days
#9 posted 186 days ago
I was told to leave wood in the clamp for 4 hours. Now days I keep reading that people are using less time in the clamps. I still try for the 4 hours and longer if it is cold.
