Type of wood for a painted Adirondack Chair?
Forum topic by StevenPortland posted 188 days ago 647 views 0 times favorited 10 replies Add to Favorites Watch
View StevenPortland's profile
StevenPortland
3 posts in 274 days
188 days ago
Topic tags/keywords: modern question adirondack chair outdoor lumber
I live in Portland, Oregon, which is a wet and rainy place. I’m planning to build two of these Adirondack chairs for our front porch. I will be painting them a bright color, similar to these chairs.
What type of lumber should I consider using? Do I need something like cedar since the chairs will be outdoors? Or because they will be painted (sealed from the weather) can I use just standard lumber?
10 replies so far
View AandCstyle's profile
AandCstyle
637 posts in 425 days
#1 posted 188 days ago
My preference would be white oak, but cypress, black locust (maybe the best if you can find it) and redwood will be good choices. Water will migrate up from the feet and eventually “standard” lumber will rot.
-- Art
View Charles Maxwell's profile
Charles Maxwell
826 posts in 1975 days
#2 posted 188 days ago
Redwood or cypress
-- Max the "night janitor" at www.hardwoodclocks.com
View Moron's profile
Moron
4433 posts in 2061 days
#3 posted 188 days ago
pressure treated decking
inexpensive, readily available and longevity assured ?
View eric122's profile
eric122
84 posts in 1178 days
#4 posted 188 days ago
you could use hemlock or western larch or ipe mohogony or tiger wood check out advantage timber out of buffalo ny they have a online store
-- eric underwood
View Richard's profile
Richard
357 posts in 859 days
#5 posted 188 days ago
I used pressure treated “1 x” and painted mine. I leave them outside year round. They have been through two Minnesota winters and about to go through a third and are still holding up very well. The paint is starting to flake in places, but that is not unexpected.
-- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain
View Purrmaster's profile
Purrmaster
401 posts in 261 days
#6 posted 187 days ago
Ah, a fellow Oregonian.
You might want to check out Woodcrafters (not the same as Woodcraft in Beaverton) in Portland. They have a good lumber selection and the folks there know their stuff.
View Sandra's profile (online now)
Sandra
1280 posts in 243 days
#7 posted 187 days ago
Hi – differing opinion here. If you have never built an Adirondack chair before, you may want to go with pine for your first go. I built my first one with very little woodworking experience and learned a LOT along the way. What that translated into was a very expensive chair. I had to recut some of the pieces several times, bought tools as I needed them, more wood, more tools….
If you use a good primer/sealer and then paint, they won’t last forever, but they’ll look good for at least a few years.
We leave ours outside for three seasons, bring them into the garage only in the winter. I’m in Eastern Canada, so we get a lot of rain in the Spring and Fall.
You could build your first out of pine, and then look at some of the other wood types.
Just my two cents worth. If you check out my projects, I have a yellow chair that’s a bit on the ‘too bright’ side.
Have fun, be safe, and ask away.
-- No, I don't want to buy the pink hammer.
View Madwood's profile
Madwood
35 posts in 1219 days
#8 posted 187 days ago
Building a prototype from pine is an excellent idea! I’ve built literally hundreds of Norm’s Adk chair and 90% of them from pine. I did a couple in cypress a number of yrs ago and they still sit on my deck. The above suggestions are all good chojces and my overall choice would be white oak. Strong and weather=resistant, it would last for a long time, especially painted. Prime first however, or you’ll be painting ever yr or so. Stain would be a good choice of finish as well.
HTH, John
-- In the shop making chaos out of order
View Monte Pittman's profile
Monte Pittman
7060 posts in 506 days
#9 posted 186 days ago
If you are going to paint it, I would go with PT pine. Handles the climate well and painted is as good as any without the cost.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
View RussellAP's profile
RussellAP
2394 posts in 454 days
#10 posted 186 days ago
Spar and then paint and you can use any wood.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
