wheels for small wooden toys
Forum topic by nate22 posted 11-13-2012 05:47 PM 6251 views 2 times favorited 16 replies Add to Favorites Watch
View nate22's profile
nate22
475 posts in 2750 days
11-13-2012 05:47 PM
My uncle and me are making small wooden toys like cars, trucks, semi trucks and other designs. My question is where is a good place to get the wheels from and what is the best way to attach the wheels to them.
-- Gracie's wooden signs. Middlebury, In.
16 replies so far
View Gene Howe's profile
Gene Howe
9939 posts in 3303 days
#1 posted 11-13-2012 06:03 PM
HERE is where I get mine.
The axle pin they sell is one way to attach them.
You can make your own wheels with a rosette cutter and a matching hole saw. The nice thing about the hole saw is that you end up with an axle hole.
View MrsN's profile
MrsN
983 posts in 3400 days
#2 posted 11-13-2012 06:45 PM
I buy my wheels from craft stores locally, but online is a great place espically if you need lots of them. Some of the big box hardware stores have them as well. Do you have a Menards? I know they have them, but don’t ask an employee they don’t always know they do.
I usually use a dowel for attaching the wheels. I find it easier to cut the dowel to the size I want then get the wheel to the end of the dowel, with out over tightening the wheels so they don’t spin.
View Jim Jakosh's profile
Jim Jakosh
19966 posts in 2980 days
#3 posted 11-13-2012 06:48 PM
Gene has your answer. It is just what I do when making rolling toys…..................Jim
View PRGDesigns's profile
PRGDesigns
234 posts in 2188 days
#4 posted 11-14-2012 04:03 AM
Another alternative would be Cincinnati Dowel, or CinDoCo. Woodcraft apparently buys their dowel stock here because I peeled a lot of CinDoCo stickers off of the hardwood dowels I purchased from them.
-- They call me Mr. Silly
View exelectrician's profile
exelectrician
2327 posts in 2302 days
#5 posted 11-14-2012 07:35 AM
The wheels for my toy train I got at craftparts.com, good service, low price. And good quality.
-- Love thy neighbour as thyself
View johnstoneb's profile
johnstoneb
2692 posts in 2047 days
#6 posted 11-14-2012 12:21 PM
Here is another source for wooden wheels. I have used them good quality and quick shipping.
http://www.americanwoodcrafterssupply.com/wooden-products/wheels-axle-pegs.htm
Bruce
Boise, ID
-- Bruce, Boise, ID
View Jim Finn's profile
Jim Finn
2599 posts in 2796 days
#7 posted 11-14-2012 09:34 PM
I use an axle pin to attach wheels.
View Howie's profile
Howie
2656 posts in 2797 days
#8 posted 11-14-2012 09:53 PM
You can make your own by using a holesaw the size you want. Drill several holes 3/4 inches(+/-)deep in a board then slice off the thickness you want on the bandsaw. 1/4” drill on the holesaw lets you use a 1/4” dowel. Drill 9/32 for the axle hole, a little sanding and you got it.
-- Life is good.
runswithscissors
2604 posts in 1899 days
#9 posted 11-15-2012 05:08 AM
Here’s a way to make your own: Start with a spade bit that has a diameter same as the diameter of the wheel you want. With a rat tail or chainsaw file, file a hollow on each side of the point (the point doesn’t need to be narrowed). With your file, bring the half-hollow out to the edge, thereby forming a spur. Drill (best with a drillpress) half way through.If the the point doesn’t show on the other face (meaning your stock is thick) finish the center hole with a small diameter bit. Turn board over and finish from other side. You could clamp a scrap board to the backside to keep your drill from skating around when you break through. Incidentally, the spurs make the spade bit much more efficient for ordinary drilling, and they drill a rounder hole, almost as clean as a forstner. Of course you’ll be limited in the size of wheel you can make. I think I have seen 1 1/2” spade bits (?) I’ve been reshaping spade bit this way for decades. Takes about 5 minutes to make one, about 1 minute to resharpen. I like to keep the spurs sharp, and always tilt the file a little to give the cutting edge a relief angle. This is like the rosette idea mentioned previously, but on a smaller scale. They will look a lot like the ones pictured in johnstoneb’s link.
View Eagledad's profile
Eagledad
26 posts in 1823 days
#10 posted 02-21-2013 03:11 PM
I get most of my stuff from Caseyswood.com They seem to have better prices than Craftparts.com.
View Randy Sharp's profile
Randy Sharp
363 posts in 3547 days
#11 posted 02-21-2013 03:20 PM
Hobby Lobby usually has a good selection to choose from.
-- Randy, Tupelo, MS ~ A man who honors his wife will have children who honor their father.
View JesseTutt's profile
JesseTutt
853 posts in 1985 days
#12 posted 02-21-2013 04:04 PM
It is true that the local Hobby Lobby has a reasonable selection, but comparing the price of Hobby Lobby to online I cannot justify the price of purchasing local. If the prices were close I would definitely purchase from Hobby Lobby.
View treborwoods's profile
treborwoods
4 posts in 2209 days
#13 posted 07-17-2013 08:38 PM
I have a variety of sizes of HSS hole cutting tools for cutting holes out of steel. My red ones have a replaceable 1/4” center pilot bit. I replace that with a 15/64” brad point wood bit on which I have filed a slight flat spot on the shaft where the set screw meets the center bit. I insert this brad bit into the hole cutting tool making sure the tip of the bit extends 3/16 to 1/4” beyond the cutting teeth of the tool.
The 15/64” inch bit is such that a 1/4” dowel rod fits so tightly into the axle hole of the wheel that no glue is needed. Attempting to remove the wheel from the subsequent toy results in twist breaking the axle.
When I use this adapted tool on the drill press I drill to within 1/16” all the way through the wood. This prevents a complete wheel blank from getting caught in the tool and assures the brad bit has completely gone through the wheel. I use a fence on the sacrifice wood deck that assures that an external wall of the hole cutting tool is exposed as the drilling progresses down through the wood blank while the internal wall touches wood all the way down. This provides an outlet for sawdust and greatly relieves the amount of heat built up.
When the initial deep hole has been cut, flip the wood over and gently re-drill using the axle hole as your guide. Yes, a 15/64 bit means there is a bit of off-centeredness involved— a whopping 1/128” of an inch. Not that your grand child lacks in perception, but my two little genius have yet to say, “Granddad, your wheels wobble!”
Bob Turner, treeborwoods@gmail.com
-- Trebor Woods
View BigJerryWayne's profile
BigJerryWayne
138 posts in 1977 days
#14 posted 07-17-2013 09:19 PM
I just got an order in last week from these folks. Prices are good. I got 200 wheels of various sizes and axles to go with them.
http://www.caseyswood.com/shoppingcart/zen-cart/
-- An oak tree is just a nut that stood it's ground.
View bobsmyuncle's profile
bobsmyuncle
110 posts in 2565 days
#15 posted 07-17-2013 11:58 PM
Yet another choice: http://www.midwestdowel.com/pages/shop/category&CatID=20
Haven’t compared the prices, but the local woodworking club buys them from Woodworks.
