| Forum topic by JNP | posted 190 days ago | 773 views | 0 times favorited | 13 replies | ![]() |
190 days ago |
Hello all, I want the groove in the middle of the board, not a cut out on each side. Any suggestions for the best way to accomplish this? I really don’t want to mess it up at this point! Thank you. Jeff -- Jeff |
13 replies so far
#1 posted 190 days ago |
Hey Jeff, before I got my router table I would use a fence attachment on the router with the board in a vice. but now that I have the router table I use that. Good luck and remember to post pictures. -- Everyone calls me Ed or Eddie , mom still calls me Edward if she is mad at me. |
#2 posted 190 days ago |
Jeff, I’m a bit confused as to what you are asking. If the board is 24” wide, 18” deep, and 2 1/5” thick, where do you want the groves? Along the center line of the 2 1/2” thickness?
#3 posted 190 days ago |
Yes, I’m sorry, after I reread my post I thought it may be confusing. Your photo is exactly what I’m looking for. -- Jeff |
#4 posted 190 days ago |
I’m guessing a core bit with the board on end at the router table, but there are probably lots of ways to get it done. -- Jeff |
#5 posted 190 days ago |
I would just set stop blocks on the fence of my router table to control the start and stop of the cut, use a core bit (or whatever groove profile you want), set the fence so the center of the bit is 1.25” from it. Ease up on the depth of cut until you are happy. And as always, test your setup on scrap first. -- - The mightiest oak in the forest is just a little nut that held its ground. |
#6 posted 190 days ago |
Something like this will work. They have lots of sizes and shank lengths. I have the 5” shank set which I flute turnings and such with. This is definately the easy way. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#7 posted 190 days ago |
Jeff, no problem, I sort of like playing with the CAD, I’m trying to learn it. Like the other guys said the router table is ideal, do you have one? If you have no router table and this is a one off project there are work arounds that might suffice. Forget what I said….. DS251 has the winning answer if a router table is not in your shop. Still use stop blocks to get the best accuracy. |
#8 posted 190 days ago |
Casual1, as you’re learning CAD, I’m trying to figure out how to make a square in Sketchup (not really, I have given up on that completely). I do have a table, but thought there might be other recommendations. It’s always a bit dicey cutting blind grooves and I don’t want to mess up the board now. DS, that bit with the bearing would give me a cove cut on the top and bottom of the board, but not a groove in the middle of the board’s end. Thanks for the replies… -- Jeff |
#9 posted 190 days ago |
Jeff, set the center of the flute at 1/2 board thickness, the bearing will follow the lower edge of the board and cut the groove you want. |
#10 posted 190 days ago |
Got it! There we go…a different way to go about it! I like that better than putting the board on it’s end. -- Jeff |
#11 posted 190 days ago |
It’s hard to shift one’s mindset once you get it in there to do it a certain way. It took me a second to realize you were stuck on cutting with the board on its end. That is pretty tough even with a router table. These side-cutting flute bits are great for what you want to do. It’s much easier and safer with your router plate on the face of the board instead of the edge. The other nice feature of these bits over a core bit is that there is no “zero-velocity” point at the center of the cut, so they produce a nice clean cut without any burning. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#12 posted 190 days ago |
That flute bit is a terrific idea! I can’t think of an easier way to do this. I do mine on the router table but I always get a bit of burning at the entry when I push the board down into the bit. |
#13 posted 190 days ago |
flute bit, core box on router table, or handheld router with edgeguide will all work. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3550 |
15787 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
