Steel Wool or Scotch Brite?? What'ya do?
Forum topic by steve6678 posted 218 days ago 705 views 0 times favorited 26 replies Add to Favorites Watch
View steve6678's profile
steve6678
438 posts in 257 days
218 days ago
have been using wool but sick of tiny metal fibers.
Tried Scotch Brite, good, but…Best is …??
-- Steve - Dust sucks!
26 replies so far
View derosa's profile
derosa
1466 posts in 1033 days
#1 posted 218 days ago
Which scotch brite? I’m in the finishing stages of a project now and had a friend give me a brown one, said it was the best hardness to use. He’s been doing this for over 50 years as his profession so I’ll see how it works out.
-- --Rev. Russ in NY-- A posse ad esse
steve6678
#2 posted 218 days ago
I was using grey…dunno what’s best for you
View RussellAP's profile
RussellAP
2430 posts in 484 days
#3 posted 218 days ago
Using steel wool on wood? Please say you’re using on metal.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
steve6678
#4 posted 218 days ago
000 rubbing in a finish
RussellAP
#5 posted 218 days ago
Have you tried Abranet Abrasives instead of wool? You can wet sand with them and I think they go up to 4k.
steve6678
#6 posted 218 days ago
you’ve never used steel wool to rub in wax, or fine out oil
RussellAP
#7 posted 218 days ago
I think many years ago I tried, but all I got was a ruined finish from the discoloration the wool left. Never went back. Of course I don’t usually work a finish to that kind of shine, I prefer satin.
steve6678
#8 posted 218 days ago
wet, as in how are you wetting, oil wet?
RussellAP
#9 posted 218 days ago
Some use compounds, or some concoction of their own. I would think a bit of oil would work but I ‘d have to check with Charles Neil about it first and he’d likely have a better idea to get the shine.
steve6678
#10 posted 218 days ago
4/0 steel wool…#0000
The simplest rubbed finish is one that is done with #0000 steel wool, or equivalent abrasive pad. Nothing more is involved than rubbing the surface in long strokes with the grain of the wood. As long as the strokes are straight and you keep an even pressure, the scratch marks you leave with the steel wool will soften and enhance the appearance and feel of the finish.
It’s unlikely you will rub through to the wood if you have applied at least three coats of a film-building finish.
But you have to be careful not to cut through the finish on edges. To avoid this, begin rubbing flat surfaces with short 3-inch to 6-inch strokes right up to the edge. Then connect these strokes with long straight strokes running the entire length of the surface, avoiding coming right up to the edge.
You can use a lubricant (soapy water, mineral spirits, mineral oil, or wax) with your steel wool, or you can rub without a lubricant. With water-based finishes you shouldn’t use mineral spirits, which can soften the finish.
steve6678
#11 posted 218 days ago
I usually rub out with steel wool 4/0 with Paste wax
steve6678
#12 posted 218 days ago
How do you conclude your finishes?
RussellAP
#13 posted 218 days ago
It depends on what I’m making. Lately I have been making a lot from cedar. I sand it to about 180 or 220 then I use Danish oil. On cedar I like to give it thick coats and let it dry between. Using mineral spirits I clean it off and to top coat I use Arm-R-Seal. One coat is enough. I’ll give it a wipe with 600g and wipe with a soft cloth. Let it set for a couple weeks to gas-off and it’s done.
steve6678
#14 posted 218 days ago
Nice.
steve6678
#15 posted 218 days ago
I am sick of buffing out finishes.
watco 2 coats…Arm r seal 1 coat, Goddards paste wax…and see ya!
No sanding in between any coats, no buffing till the final paste wax.
Sand everything to 320 beforehand.
