| Forum topic by Cole Tallerman | posted 190 days ago | 348 views | 0 times favorited | 3 replies | ![]() |
190 days ago |
Hey, so I just ordered my Bosch 1617 router and I’m building a table. Can someone give me the height and width of the router in the fixed base? The with should be without handles because I bought the table base for it. Thanks in advance! |
3 replies so far
#1 posted 190 days ago |
Bump. C,mon jocks! |
#2 posted 190 days ago |
Hang on, Cole. I’ll go out and measure mine… OK, the diameter of the fixed base is 6 inches. There’s an adjuster though that would “stick out” of that 6 inch diameter circle by half an inch or so. Height is variable depending on where you have it latched, but if you’re looking for a good height under the table, mine is 12 and a half inches from the underside of the plate, to the bottom of the cavity in which the router lives. This gives me JUST enough room to drop the motor out of the base from underneath. Otherwise I have to remove my fence, lift the router plate, base and motor out through the top. That what you’re looking for? |
#3 posted 189 days ago |
Just finished the motor compartment thanks to your measurements. That was exactly what I was looking for! Thanks so much! |
| Forum | Topics |
Woodworking Skill Share
8791 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1530 |
3547 |
15768 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
