Baseboard Radiator Covers
Forum topic by Patrick Riley posted 11-12-2012 04:14 AM 19035 views 1 time favorited 6 replies Add to Favorites Watch
View Patrick Riley's profile
Patrick Riley
6 posts in 2039 days
11-12-2012 04:14 AM
Good Evening All,
I just moved into my new house and it has hot water baseboard heaters on pretty much all the walls. The house is 62 years old and the baseboards are in rough shape which means they need some updating. I have been searching the web for some ideas of what other people may have done but there’s not much out there. I have found a picture of something that I’m going to use as a rough plan but I want to know if anyone else has had some sort of experience with this??
Pat
View Dan Krager's profile
Dan Krager
4000 posts in 2230 days
#1 posted 11-17-2012 02:09 AM
The picture shown is beautiful. If you do something like this, be sure to use well dried poplar as your base wood. Anything else is likely to give you trouble due to proximity to heat. You will want to make some part of it removable for cleaning out the inevitable dust bunnies that clog circulation. And all surfaces, front, back, top, bottom, ends get the same finish treatment (or else!)
I used to build entire cabinets over baseboard heaters. The trick was to use a false back and false bottom with enough vents to provide the original circulation. The cabinet itself had to be vented at least on top to let accumulated heat escape. I usually concealed the vents in the toe space and behind shutters or other distraction.
Good luck!
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com One should always prefer the probable impossible to the improbable possible.
View AandCstyle's profile
AandCstyle
3051 posts in 2253 days
#2 posted 11-17-2012 02:21 AM
Could you use MDF for the raised panels? Would that be a less expensive option than poplar?
-- Art
117090 posts in 3573 days
#3 posted 11-17-2012 02:28 AM
cool design Pat, great job.
Patrick Riley
#4 posted 11-17-2012 02:54 AM
Thanks for the input. I think MDF is what I am going to use. I just finshed making the baseboards for the other walls that don’t have heaters on them and MDF is what I used. It worked well and was much cheaper than buying pre made baseboards from the hardware store plus I was able to get the exact look I wanted.
Dan Krager
#5 posted 11-17-2012 07:17 PM
Yes, MDF will work pretty well. The product has improved greatly in recent years but my early experiences with it left much to be desired back then.
Good Luck.
DanK
View Bill White's profile
Bill White
4929 posts in 3956 days
#6 posted 11-17-2012 08:12 PM
Using an exterior grade MDF would be even better. It is more dense, and when sealed with a good primer (I use Seal Coat) will paint very well. This stuff is almost bullet proof.
Bill
-- bill@magraphics.us
