Dust collection types
Forum topic by hoosier0311 posted 220 days ago 399 views 0 times favorited 6 replies Add to Favorites Watch
View hoosier0311's profile
hoosier0311
145 posts in 222 days
220 days ago
I have outgrown my shop vac type system. Time to move up to something better. I see Harbor frieght has a two horse modle very reasonably priced,,,,,,,,,,,,,,,,,,,,,,but I’m a bit leary of harbor frieght stuff. Does anyone have any first hand knowledge of the HF model?
next anyone have a recommendation for one?
Thanks in advance for your input.
-- I do not have attention deficit dis,,,,,,,,,,,,,,,,,,,,,,,hey look ,it's a bunny
View Straightbowed's profile
Straightbowed
635 posts in 495 days
#1 posted 220 days ago
I is goin with the grizzly wall mount dust collectors and blowing it outside into a trash can but I live on a farm Grizzly is having a sale on dust collectors it’s the christmas sale check that out they have good collection
-- Stevo, work in tha city woodshop in the country
View 47phord's profile
47phord
137 posts in 434 days
#2 posted 220 days ago
I have it and have no complaints. If you pick up Wood Magazine (there may be others as well), they usually have a coupon for one at $149. I added a Thein top-hat setup to mine to help filter out the dust, and I plan to add a Wynn cartridge filter at some point. It works well enough if you don’t mind moving the hose around your shop. If you want to go with a dedicated, ducted system you may want to go with something a little more powerful.
View TheDane's profile
TheDane
2697 posts in 1860 days
#3 posted 220 days ago
I don’t have a Harbor Freight dust collector, but a lot of LJ’s do and the reviews/comments are generally very strong.
Many LJ’s outfit them with cannister-type filters from Wynn ( http://www.wynnenv.com/ ).
For the money, I don’t see how you could go wrong.
—Gerry
View RussellAP's profile
RussellAP
2428 posts in 483 days
#4 posted 220 days ago
I like mine although I only use it on the planer right now. I still like a shop vac under my TS. My tools get moved around too much for a DC run to each of them.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
857 posts in 690 days
#5 posted 219 days ago
The 2 HP HF DC is really well regarded, and generally shows up as one of the “gems” for HF. If you compare it to other brands, be sure to compare things like motor amps and impeller size as opposed to any funky HF ratings.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
View Cato's profile
Cato
641 posts in 1509 days
#6 posted 219 days ago
You will like upgrading from the shop vac, no matter what you settle on.
Like the other posts, many have gotten the HF and put the Wynn on it and seem totally pleased.
When I upgraded from the shop vac, I got a cannister DC from Penn State which has worked great for me.
I found that using one of those trashcan separators worked great for my machines that generate a lot of sawdust in a short bit of time, like at the start of a project when I am batch milling on jointer, planer, and TS.
