Problems with miter saw cutting at an angle.
Forum topic by itsme_timd posted 1740 days ago 1404 views 0 times favorited 6 replies Add to Favorites Watch
View itsme_timd's profile
itsme_timd
687 posts in 1999 days
1740 days ago
Topic tags/keywords: miter saw adjust 45 question
Hi LJ’s,
I’ve got a Firestorm 10” miter saw an I’m having issues with it cutting straight. For example, I needed to cut a piece on a 45 yesterday and when I made the cut it ran at an angl across the piece.
Here’s an artist’s rendeering of what I’m experiencing…
I can’t fnd the manual to my saw (of course) and I’m not sure how to adjsut this or if it is adjustable.
Any help is greatly appreciated!
-- Tim D. - Woodstock, GA
View Steelmum's profile
Steelmum
355 posts in 2130 days
#1 posted 1740 days ago
I just went to the Firestorm website. They have manuals for download in the customer service area. I am not familiar with your saw. I just use a small square and make sure my blade is square to the table and the fence.
-- Berta in NC
View lew's profile
lew
8979 posts in 1923 days
#2 posted 1740 days ago
From your picture, it looks as though the vertical position is off a little.
As “Steelmum” said, use a small square to check to see if the the blade is perpendicular to the table. also use a framing square to check if the blade travels perpendicular to the back fence.
Lew
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
27262 posts in 1990 days
#3 posted 1740 days ago
One tool that I have found helpful with setting my miter saw is the Wixey digital angle gauge.
Tony has posted a review of it here.
This tool is well worth the money.
itsme_timd
#4 posted 1740 days ago
Thanks everyone, appreciate the info – it’s a big help.
View mbike1356's profile
mbike1356
3 posts in 1779 days
#5 posted 1738 days ago
is the saw a compound angle saw? if it is the 10” 15-Amp Miter Saw with Laser (FS100L) then there is an adjustment knob in the back of the saw that allows for the head to be moved to an angle. This is probably out of kilter loosen the knob and make the adjust ment necessary with a square and probably a wrench. The saw will sometimes move out of adjustment just by picking it up by the handel. It is always a good practice to verify trueness in new tools befor you do anything else with them. This will often times enlighten you to things the tool is capable of when you had no idea
View SteveKorz's profile
SteveKorz
2119 posts in 1882 days
#6 posted 1738 days ago
I had something similar to this happen to me on my DeWalt. It cut great for a long time, then I switched blades (went to a cheaper one), and it cut terribly. The blade would actually cut crooked and at an angle thru the wood when the squares said everything was good and straight. I junked the blade, and bought a really nice one. Now, it cuts like a dream.
You might check for excessive bearing play, and almost all of these have adjustments that you can make to the “0” mark for square. Go to the manufacturers website and you’ll probably find a manual.
Good luck,
—Steve
