Full-Time ZCI?
Forum topic by Don Broussard posted 189 days ago 584 views 0 times favorited 20 replies Add to Favorites Watch
View Don Broussard's profile
Don Broussard
587 posts in 416 days
189 days ago
For those of you LJs who have and use ZCIs, do you leave the ZCI on the saw full-time or do you only mount the ZCI when you are cutting thin parts? I am thinking that full-time ZCI makes sense, but I’d like to hear others’ experiences.
For those who commented on my project “Laminate Flooring ZCIs”, I thank you. I judged that this question is more of a forum topic than a project, so pardon the seeming repetition.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
20 replies so far
View Edziu's profile
Edziu
143 posts in 1216 days
#1 posted 189 days ago
First off- nice Zero Clearance Inserts.
The simple answer to your question is Yes, I leave my ZCI’s in all the time. Like you, I made a bunch at once, in case i’m using a thin-kerf blade or for various dado sizes.
But more importantly, ZCI’s are not just for using when you are cutting thin parts. They are extremely helpful in achieving a really nice cut on your table saw. With the insert in place, you give the wood fibers more support when being cut, which results in a nice, sharp, clean cut on your material- especially plywood.
View Jeff in Huntersville's profile
362 posts in 1359 days
#2 posted 189 days ago
All the time except when using dado or when tilting the blade. I have different inserts for these operations.
View oldretiredjim's profile
oldretiredjim
104 posts in 550 days
#3 posted 189 days ago
Have several I made out of MDF. Fit perfectly without shims. I swap inserts when I swap blades. Never use the stock insert.
View TheDane's profile
TheDane
2672 posts in 1828 days
#4 posted 189 days ago
Full time. My ZCI has replaceable inserts for different blade/dado widths.
—Gerry
Rick Dennington
2884 posts in 1359 days
#5 posted 189 days ago
I don’t use ZCI’s….don’t like them…..I made several. Still don’t use them…..!!
-- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!!
View NiteWalker's profile
NiteWalker
1462 posts in 742 days
#6 posted 189 days ago
+1 on full time except for dado or tilting the blade.
Not using one and ripping thin stock is a safety hazard and I can’t see why anyone wouldn’t use one.
View pintodeluxe's profile
pintodeluxe
1731 posts in 978 days
#7 posted 189 days ago
Full time ZCI except for angled-blade cuts. Separate ZCI inserts for each common dado configuration. I made mine from mdf covered in red laminate. I installed laminate on both sides of the mdf, and they hold up great.
Don Broussard
#8 posted 189 days ago
Thanks for validating my judgment. LJs have again met my expectations and do not disappoint.
@Edziu—Good point about continuous support of work pieces. I might just do a comparison with a stock insert and the ZCI to see the difference.
@oldretiredjim—Do you recommend exact fitting, or have you tried cutting them shy and adjusting to fit via set screws, shims or hot glue?
View bondogaposis's profile
bondogaposis
1236 posts in 516 days
#9 posted 189 days ago
I have lots of different ZCI’s, some have a splitters, some don’t. Some are for, thin kerf, some are for full kerf. Then there are the dado’s and angled cuts, I have ZCI’s for them too. I always have a ZCI in the saw at all times but change them to suit the blade or cut.
-- Bondo Gaposis
View Rick M.'s profile
Rick M.
1455 posts in 545 days
#10 posted 189 days ago
All the time for square cuts.
-- -- Rick M.
View Rob's profile
Rob
51 posts in 1151 days
#11 posted 189 days ago
I have a question about ZCI’s I have one made out of phenolic and I drilled a hole in it to secure it to the table like the original metal one that came with the saw. Do you secure your ZCI with a screw or just lay it in there?
View Joshuah's profile
Joshuah
149 posts in 858 days
#12 posted 189 days ago
I only use ZCI’s! I love mine and am quick to replace them if they are damaged in any way. The only time I remove mine is for angled cuts.
-- -Joshuah
View RussellAP's profile
RussellAP
2394 posts in 451 days
#13 posted 189 days ago
I use Lee Craft inserts and I only use the ZC on thin cuts. It causes a lot more sawdust to get on the surface of the TS when you use the ZC so I use the stock most of the time. Can’t wait to try out my ZCDI.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
View mloy365's profile
mloy365
305 posts in 1295 days
#14 posted 189 days ago
I use ZCI all the time including angles and dados. I make them out of corian or meganite counter scraps from some local counter top shops. I just bought the Colli-Beck insert, but I will still be making out of counter top as well. Colli-Beck insert is totally awesome, but you have to spend a few $.
-- Mike - Northern Upper Michigan
View CessnaPilotBarry's profile
CessnaPilotBarry
598 posts in 275 days
#15 posted 189 days ago
I leave it in for square cuts.
I don’t use an insert at all when using a crosscut sled.
-- It's all good, if it's wood...
