| Forum topic by sonnyr | posted 197 days ago | 847 views | 0 times favorited | 10 replies | ![]() |
197 days ago |
Topic tags/keywords: question dc dust collector duct pvc metal duct I have been reviewing a lot of dust collectors and ducting for my workshop. The shop is 16’ x 32’ (512 sq.ft.) with 8’ walls. I have been looking at getting the JDS 3hp cyclone 3100-CK (2300 cfm) or the CV1800 Clear Vue (1442 cfm.). I have an older Delta planer, Rigid 3650 TS, router table, drill press, 14” bandsaw (Taiwan look alike), wood lathe, disc sander, and miter saw. -- I may be slow, but I'm easy to stop!!! |
10 replies so far
#1 posted 197 days ago |
Sonny, -- Art |
#2 posted 197 days ago |
Sonny, -- Art |
#3 posted 197 days ago |
I too learned a lot from Bill Penz. I have a clearview and I like it. I would recommend putting it outside your shop if that is an option. They are very noisy. Many people recommend metal piping but I used 6” PVC and typically dropped it down into 2 – 4” connections. The 6” pvc has gotten VERY expensive in my neighborhood. You may want to price it out because you may blow your budget quickly. Learn to make your own fittings and reducers. You can save a lot of money. You can see some of my connections under “My Work Shop” in my profile. I list things that I really like and things I would do differently if you read the post. -- Sorry the reply is so long. I didn't have time to write a short reply. |
#4 posted 197 days ago |
We just set up a 5hp cyclone. We used 6” galvanized 24g all the way to our machines. Just beore the machine we went to 6” flex. We used metal blast gates. Bought our flex and gates from Pennstate. The 6” galvaized , bought from Global Industrial online, was so inexpensive, I certainly thought it was a situation where “you get what u pay for”. But that was not the case as our duct is very strong. I am very happy with our set up. My next phase will be to swap out the 6” main trunk and go with 8”. -- Jerry Nettrour, San Antonio, www.topqualitycabinets.net |
#5 posted 197 days ago |
I have 3 hp Laguna, Supposedly Penn State makes these, but with bigger impeller. I had 6 ” PVC, hated it due to lack of consistency in fittings, need for a lot of jury rigging. bought Penn State 20 gauge, metal blast gates, in 15×21 shop with plans for additional 400 sq ft expansion. I would definitely locate outside of shop and split in the middle. Have to allow for inflow of air from clean exchange to outside air. |
#6 posted 197 days ago |
I to have the clearvue and I am so glad I spent the extra bucks for it. As stated, it is noisy. But, if placed in an insulated closet, it will really cut down on the noise…........so a conversation can be held between people. |
#7 posted 197 days ago |
Thanks for the input folks. Does anyone have experience with a JDS 3hp cyclone 3100-CK (2300 cfm) ? -- I may be slow, but I'm easy to stop!!! |
#8 posted 197 days ago |
Do a search of other posts here on LJs. There are some good comments there. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#9 posted 196 days ago |
lots of info on that subject on LJs…i built my own cyclone..mounted the blower outside..all i can here is a little humm…in my projects -- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA. |
#10 posted 143 days ago |
I am new to wood working in general and dust collection specifically. Now retired, i have recently started a stand alone shop 20X24’ and have been reviewing for the past week or so the various options to install. Honestly I had not anticipated such a diverse grouping of opinions and the mix of conflicts out there. I think I have changed my mind about 4 times in what to do, which in not my usual way of doing things hense this post. I have come to think of this as dust collection skirmishes..claims and counter claims…. I have been through Bill Pentz’s site and appreciate the value of fine dust control and the clear vue collector, it certainly has a loyal following. The only two issues I have is the height and noise. Out side is not a good option and space for a closet to house it in is not appealing. Frankly i can live with the noise…its down to size. I was focused in on the JDS 3hp system that this original thread was asking, which is how I found this thread. Not sure if the question was answered or not and if not were folks being polite or just had no experience with this system. I like the compactness and it is shorter which works better in my shop. The owner reviews were generally positive but no real data on the fine dust collection and the pleated filter surface area is certainly smaller than the clear vue…good CFM, smaller cyclone ..any real world experince out there with this set up. There is some questions about the need to automatically clean the filter presnted as a flaw? All filters need some cleaning either with a manual padle, automated or compressed air. Given motor and impeller size as constants, the most pertainate issue is the size of the surface area of the filter and is that up to the job of fine dust collection along with the efficency of the cyclone itself. As an aside i have read that there are manufacturers who present the performance data in a flawed way that does not match real world perfomance, not sure if this is true with either JDS or the simular Laguna product but of someone has information on this it would be helpful! As I write this it seems the Clear Vue is the most appropritae option but I am looking for justifications to go the JDS route due to size and compactness Finally the debate of whether to use PVC or metal ducking..wow some imteresting opinions. I was focused on the PVC fpr cost and ease of working with it and became concerned about static charge and moved to planning a metal ducking, then later was convinced you could minimize static charges and ground the system using metal tape. I have yet to find anywhere or anyone one who knows of has reported any static caused fires in a home shop? I have come to understand the value of a good sized pipe and plan on using 6” all the way to the equipment and connecting as best I can to the largest sized possible. Limit flexable hoses. Ok so there it is….i have concluded that the dust collection system is really really important for health reasons and looking at doing the right thing. Want to do it right and not later regret the decsion I am inexperienced enough to admit it and feel a bit bogged down with conflicting information, knowing i need to do something (as an aside I have a 1 hp Jet bagger dust collector that at most does ok chip collection otherwise blows out more fine dust than is reasonable. It is not up to the job. i did add a trash can collector in line but that is a stop gap measure until i purchase and build a new system, also just added a hanging Jet air filtration, which i do like but understand this might not get all of the fine dust) I really value Input and constructive criticism, it is important to have a clean amd safe workong environment. Does anyone have an air quality meter they use and if so what results with your system -- John Coyle, Kilmarnock VA |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15806 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
