DC Dust Deputy Marriage
Forum topic by Randy Woodworker posted 11-08-2012 05:21 PM 3871 views 2 times favorited 7 replies Add to Favorites Watch
View Randy Woodworker's profile
Randy Woodworker
68 posts in 2473 days
11-08-2012 05:21 PM
I wanted to incorporate an Oneida Super Dust Deputy into my system but also wanted to reduce the footprint. I disassembled the DC, and rotated the blower 90 degrees. This required a transition piece that my welder buddy made from scrap 1/8” steel. You could use hose as well, but the spool piece is skookum.
The large duct between the blower and ring is no longer required.
I built a support structure and screwed it to the wall. Here is the unit assembled.
The black support rod for the ring was now too short to reach the floor. I just drilled two holes through the rod and screwed it to the wooden support structure. The end is kinda just hanging there and I might fabricate a more elegant solution later.
In this configuration, you need to lift the barrel up to the lid, so I made a crude little cart with a lever system. A wedge keeps it tight against the lid and takes the weight. To dump the barrel, pop out the wedge drop the barrel and wheel away. Reverse for reinstallation.
I cut a hole and glued on some lexan so that I can peek inside to see when the barrel is getting full. A small LED flashlight helps with this.
Of course, for a taller barrel, the entire assembly would have to be higher. No doubt this would be desired by those who plane a lot of lumber. It would be easy to just lift the blower/Deputy assembly and use hose between that and the filter ring, but more floor space would be required and I didn’t want to give up the space where the computer and stereo are now. I will just dump the barrel more often.
This system works great. Hardly any dust makes it into the bag, and suction is very robust. Very happy.
7 replies so far
View lanwater's profile
lanwater
3111 posts in 3078 days
#1 posted 11-08-2012 09:08 PM
I did very similar thing. It works great so far.
-- Abbas, Castro Valley, CA
Randy Woodworker
#2 posted 11-08-2012 09:44 PM
lanwater, that looks very compact. Terrific. It is easier to do with hose between the two components for sure.
How are you supporting the blower? Is the Dust Deputy taking all the weight on that ring? How do you stop it from tipping side to side? How to you handle the drum?
lanwater
#3 posted 11-08-2012 10:43 PM
Yes the motor is sitting right on the top with no support. That’s one of the 2 weeknesses I identified.
The other being the wheight of the motor potential bending the cage of the impeller. The metal there is thin and held originally with few screws.
I plan a 2.0 version but like anything else it is waiting. Suprizingly there is very little movement on the blower when I move the DC around.
I lift the whole cyclone part with 2 cheap clamps from “HF in spreader mode”; all I need is about an inch to clear those bolts. That part works pretty good. You can see the spreader on the side in this picture.
lanwater
#4 posted 11-08-2012 10:45 PM
The spreader lift the plywood only which in turn lift the deputy and the motor.
Randy Woodworker
#5 posted 11-09-2012 01:33 AM
Ianwater,
A word of caution if you want to support the motor using the motor base (which is what you should do). The uprights on mine that support the weight needed to be very strong. I originally used one 2×4 but it flexed considerably. I had to screw another 2×4 on top of the first one to stiffen it up. Of course if you know a welder, a metal frame would be much better. Mine is not mobile, but I don’t need it to be. A metal frame would work better if mobility is required. I am still amazed at how well this works.
View exelectrician's profile
exelectrician
2328 posts in 2571 days
#6 posted 11-09-2012 01:43 AM
RyanIra You did a fantastic job of this, reducing air drag, and footprint at the same time. Really fantastic something that onida ought to copy.
-- Love thy neighbour as thyself
lanwater
#7 posted 11-09-2012 05:50 AM
Thanks for the info RyanIra. I have been debating 2×2 vs a tubular structure. I am leaning toward a tripod style of frame for the motor.
I am also tempted to cut a circle on the top of the deputy and remove the impeller cover so I can join the two; I think I will get more suction.
anyway you got a great setup and that welded piece was a great idea.
Thanks!
