Long sleeve, mid sleeve or short sleeve in the workshop?
Forum topic by JesseTutt posted 11-08-2012 04:09 PM 2217 views 0 times favorited 25 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2346 days
11-08-2012 04:09 PM
Topic tags/keywords: question shop dress winter clothing safety
As winter approaches, I find myself moving from the tee shirt to adding a flannel shirt over the tee. Eventually it will be thermal under garments. But, I don’t like to have long sleeves near power tools for safety reasons.
I am thinking about taking a couple of “work” flannel shirts and cutting off the sleeves so they just cover the elbow (what I call mid sleeve). The same with thermal under garments.
I would be interested in how you approach winter dress in the workshop.
Note: due to financial considerations it is not practical (cost) to heat the shop to much more than 50 degrees in the winter.
25 replies so far
View junebug's profile
junebug
102 posts in 2640 days
#1 posted 11-08-2012 04:15 PM
when it gets cold, I have a cold weather compression shirt made by under armor that I wear. Fits super tight on my arms… I’m not concerned with it getting caught on anything
View dbhost's profile
dbhost
5767 posts in 3468 days
#2 posted 11-08-2012 04:21 PM
It depends on the machine I am working on. I wear a long sleeve flannel when i don’t want to heat, up to the point that I start working on certain power tools. My big concerns are…
#1. Lathe. Under NO circumstances use the lathe with long sleeves. #2. Table saw. It’s less risky, but still risky. #3. Drill press.
Everything else, drill, jig saw, circ saw, recip saw, band saw, scroll saw etc… I am comfortable using safely with long sleeves. Just keep the sleeves buttoned at the wrists and you should be fine. No big floppy sleeves though, normal flannel type sleeves that stick close to your arm is best.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2605 days
#3 posted 11-08-2012 04:25 PM
I wear lots of tassels whenever I’m going to be operating power tools.
View Bill White's profile
Bill White
5148 posts in 4196 days
#4 posted 11-08-2012 04:27 PM
Sweat shirt with the sleeves pulled up while operating some tools.
Bill
-- bill@magraphics.us
View Elizabeth's profile
Elizabeth
817 posts in 3379 days
#5 posted 11-08-2012 04:35 PM
T-shirt. I have a zip up fleece jacket in the shop. If I’m using hand tools or planning/tidying, I have it on. Power tools, I take it off. I also have a heater in the shop to take the edge off on really chilly days.
117417 posts in 3813 days
#6 posted 11-08-2012 04:41 PM
long sleeves are fine as long as the fit snugly around your wrist.
View mloy365's profile
mloy365
444 posts in 3366 days
#7 posted 11-08-2012 04:46 PM
As usual, I agree with a1Jim.
-- Mike - Northern Upper Michigan
View David Craig's profile
David Craig
2137 posts in 3345 days
#8 posted 11-08-2012 04:46 PM
I work in a partially heated shop. During the winter, I start with long sleeve flannel until I am warm enough to take it off. I don’t wear it loose. I am not opposed to long sleeves on the lathe, I just won’t roll them up. Wood shavings can irritate the skin and the sleeves provide some protection. One thing to remember if you cut the sleeves to elbow length – Make sure that they are properly seamed on the ends that you cut. Threads start to unravel and those threads pose a higher risk of getting caught than a full sleeve in my opinion. Good question and good observations about shop safety.
View Ripthorn's profile
Ripthorn
1459 posts in 3221 days
#9 posted 11-08-2012 04:47 PM
I have a work jacket that hangs in the shop that has elastic around the wrists, so there isn’t really anything loose.
JesseTutt
#10 posted 11-08-2012 04:53 PM
I should have mentioned that I don’t have much luck keeping sleeves rolled up.
View muleskinner's profile
muleskinner
923 posts in 2672 days
#11 posted 11-08-2012 04:54 PM
naked
(photo deleted)
-- Visualize whirled peas
View chrisstef's profile
chrisstef
17798 posts in 3242 days
#12 posted 11-08-2012 04:59 PM
Ed – Sweeet tassles.
Ive got a shop hoody that i wear. Covered with filth and sawdust. No strings in the hood. Removed for safety.
View Jeff's profile
Jeff
500 posts in 3430 days
#13 posted 11-08-2012 05:09 PM
Muleskinner – you must get splinters in interesting places
View ChuckV's profile
ChuckV
3183 posts in 3763 days
#14 posted 11-08-2012 05:10 PM
My shop is unheated. When it is cold, I wear a vest jacket over a sweatshirt. I roll up the sleeves of the sweatshirt when using machinery.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View MonteCristo's profile
MonteCristo
2099 posts in 2424 days
#15 posted 11-09-2012 05:07 AM
I’m with a1Jim.
