Wooden Bearings and Prairie Schooners
Forum topic by Dallas posted 11-08-2012 02:07 AM 1116 views 0 times favorited 5 replies Add to Favorites Watch
View Dallas's profile
Dallas
3599 posts in 2570 days
11-08-2012 02:07 AM
OK guys, no pictures to share, but then there isn’t much to see as these are covered by a metal hub.
We have a little metal cart that goes behind our yard tractor and about once a year we have to replace the OEM tires at $10/ea. The new tires come with wheels and bearings, but the bearing are really cheap and wear out within a couple of months. A pair of bearings is about $11 and wears out just as quickly, even if I pack them every couple of weeks.
I got tired of this so I decided to make some wooden bearings with the thought that they couldn’t be much worse than the metal ones, the problem was, the OEM wheels had a cone shaped hub so only the end of each bearing would contact the hub and the axle at the same time.
Enter Harbor Freight:
I bought 2 13X4 2 ply knobby dolly wheels rated at 300 Lbs each. These had bearings for a 5/8” axles but mine was a 3/4” axle so I decided to take a page from the old wagon builders and use wooden bearings.
I grabbed a scrap of white oak and using a 3/4” Forstner bit, made a hole about 1/2” deep then removed that bit and used a 1 1/2” hole saw that centered on the pilot hole the Forstner bit made.
I cut the round out, (the 1 1/2” hole saw cuts a 1 3/8” ID plug), then finished the center hole with the Forstner bit.
They are a bit loose, but the tractor never moves or 7MPH so no problem. I’ve regreased the bearings 2 times this year and hauled close to 50,000 pounds of green oak trees cut up in chunks that I can lift.
I miked the bearings each time and have found no wear yet.
I did have to replace one of the bearings due to driving it off the axle and I had accidentally cut it on a knot.
All in all, I am a happy camper with this and it has saved our employer a couple hundred dollars, besides it makes my little wood shop more valuable to him!
If you want pictures, I can take some but there isn’t much to see.
5 replies so far
View RussellAP's profile
RussellAP
3104 posts in 2370 days
#1 posted 11-08-2012 02:15 AM
Jolly good show old chap. Always nice to redesign something that works better than store bought I say. And I have no idea why I’m typing as an English gentleman. I’m just feeling it.
View LittlePaw's profile
LittlePaw
1571 posts in 3161 days
#2 posted 11-08-2012 03:54 AM
Good valuable info, Dallas. Thanx 4 shar’n!
-- LittlePAW - The sweetest sound in my shop, next to Mozart, is what a hand plane makes slicing a ribbon.
View Harryn's profile
Harryn
70 posts in 2671 days
#3 posted 11-08-2012 10:18 PM
Somewhere in my 77 years, I came across wooden bearings for gristmill machines made from lignum vitae wood.
It is supposed to be self lubricating.
View Bill White's profile (online now)
Bill White
5008 posts in 4044 days
#4 posted 11-08-2012 11:00 PM
Bois D’arc (bodock here in the South) will work too.
Bill
-- bill@magraphics.us
Dallas
#5 posted 11-09-2012 12:32 AM
Harryn, I have never run into Lignum Vitae but I would like to.
Bill, I use ‘Bodark’ (here in Texas), for a lot of stuff. I only have a cheap Dewalt Bimetal hole saw and a Porter Cable Forstner bit set.
It takes nearly 4” of bearing to cover each side and my HF drill press doesn’t go any slower than 660 rpm. I would hate to wear them out with high speed heat.
