Help with an grain cutting board
« back to Coffee Lounge forum
Forum topic by lew posted 110 days ago 205 views 0 times favorited 9 replies Add to Favorites
View lew's profile
lew
1751 posts in 292 days
110 days ago
Topic tags/keywords: question walnut maple cutting board help
After seeing all of the beautiful examples, here, I could not resist trying to make an end grain cutting board. As it was my first attempt, I decided to use some scraps. After gluing and clamping, I had a flat maple and walnut blank that was about 12” x 18” x 7/8”. It sat for about a week on the workbench before I started sanding. Using the belt sander/80 grit, I smoothed the imperfections on one side. Checked to make sure it was still flat and it was. Then flipped it over and did the same to the other side.
When I picked it up, I had bowed, in the long direction probably about 1/16”!! I double checked to make sure I had not sanded a “cup” into one side- nope- it is bowed!
Right now it is sitting on a couple of strips with a chunk of railroad rail in the middle hoping to “unbow” it.
Any suggestions as to what went wrong?
Lew
View HokieMojo's profile
HokieMojo
414 posts in 265 days
110 days ago
maybe moisture in the glue caused this and it will straighten if it keeps drying?
View TedM's profile
TedM
1411 posts in 269 days
110 days ago
Heat from the sander?
View marcb's profile
marcb
199 posts in 210 days
110 days ago
When I made mine I used a “jointing” jig with my Router to cut it flat. Then sanded out the imperfections (pulled some of the grain out) with a ROS, then polished it up.
That worked well.
View lew's profile
lew
110 days ago
Thanks for the ideas. Maybe it was the heat generated by the belt sander as Ted mentioned.
Anyway the piece of railroad rail seems to have done the trick. It is back to being flat after about 6 hours.
Gonna get a new belt tomorrow and see if that might cut down on the generated heat.
Thanks Again!
Lew
View Tim Pursell's profile
Tim Pursell
222 posts in 319 days
110 days ago
I usually sand a little on one side, then flip it & sand the other side. if the wood is getting more than a little warm, flip it & work the other side. Keep flipping it & you won’t run into that problem again.
-- http://www.grandprairiewoodworks.com
View Sac's profile
Sac
203 posts in 170 days
106 days ago
Great Post Lew. I have a sack full of scrap that I am looking to build a chopping block with. I’ll have to be careful with the belt sander for sure after reading this. I’m curious, where did you come across the railroad tie? I would love to get a piece of one of these.
-- Jerry, Measure 10 times cut once. Set in the foothills of the Smokey's
View NY_Rocking_Chairs's profile
NY_Rocking_Chairs
277 posts in 134 days
106 days ago
One thing I have noticed is if I sand one side of piece and leave it laying flat on a bench it will bow since the one side is getting a lot more exposure to the air than the other. I always leave pieces either raised on blocks or standing leaned against a wall so that both sides get the same air exposure.
-- Rich, WNY, www.nyrockingchairs.com
View Brad_Nailor's profile
Brad_Nailor
728 posts in 494 days
106 days ago
What Rich said. you should never leave wood flat on a bench, especially something like doors, or a tabletop, or a cutting board. I always put some scraps under it so air can circulate all around the piece.
-- Women love me.....trees fear me
View lew's profile
lew
106 days ago
Thanks for the tips!
Purchased a new belt for the belt sander and that helped reduce the heat generated. Also, sanded a little on each side to prevent heat build up. That seemed to do the trick.
Jerry- Actually it was a gift! One day I mentioned to a friend that I was thinking about getting a small anvil. I said my Grandfather always had a piece of railroad rail in his shop to use as one but I didn’t know where to get a piece of rail. Well, last Christmas my friend shows up with this HEAVY package. Yup, a piece of rail!
It’s real handy because it works like an anvil, a super weight and a door stop. He told be he was driving and at a rail crossing there were some short pieces of rail and he promptly liberated one. Took it to a machine shop and had them cut it into smaller sections- instant Christmas presents.
Lew
Bookmark And Share This Page
