Advice needed to finish Trunk
Forum topic by 69BBNova posted 11-07-2012 09:38 PM 1174 views 0 times favorited 15 replies Add to Favorites Watch
View 69BBNova's profile
69BBNova
341 posts in 2456 days
11-07-2012 09:38 PM
This trunk was actually never supposed to be, it started as just a box (sides, bottom, top) just to get rid of wood under my bed…
Unfortunetly ever time I was almost finished I’d look at the wood scraps and just kept adding to it…
Wherein lies the problem, the top, front and rear banding is red oak, the front and rear panels are red oak plywood the sides are a combination of that edge glued stuff from lowes (main panels), and the banding is God knows what, and the verticals are hardwood something (wish I could be more specific)...
I’ve considered oak veneer, I have some 4” wide iron on from lowes but its made from two 2” strips and I’m not too crazy about that plus I’m afraid it will loosen up over time…
I will be able to resaw in another day or two but I’m actually still scared it will free up over time.
I have read about various ways to bond the veneer but I’ve never done it before, I’d like to give it to my niece and shes going to be on this Earth far longer than I.
15 replies so far
View pintodeluxe's profile
pintodeluxe
5819 posts in 3053 days
#1 posted 11-07-2012 10:03 PM
If you want a consistent look, I would paint it.
I don’t know of a stain that will mask the color of those disparate wood types.
Darker stains usually hide more, but they won’t hide everything.
69BBNova
#2 posted 11-07-2012 10:11 PM
I’ve also considered using oak veneer on the main side panels then using India Ink to darken up what I dont want to see…
She knows it will be hers (also knows about the nature of it), she intends to put in her and boyfriends tools in it, otherwise I would never give it to anyone.
View dhazelton's profile
dhazelton
2805 posts in 2536 days
#3 posted 11-07-2012 10:59 PM
Why not leave as it is – a crazy quilt of a trunk. Could even store a crazy quilt in it. Celebrate what it is and don’t make your life any more complicated.
View David Craig's profile
David Craig
2137 posts in 3348 days
#4 posted 11-08-2012 12:07 AM
Personally, I would skip the veneering. The time to do that would have been during the boxes construction stage. It is what it is and your niece already knows the history. The chest was created in fragments, out of scraps, which has its own charm. Any attempts to cover its history will not look good, I can almost guarantee it. It is going to be used as a tool chest, it should serve well as that and it is a good reminder that some creations can be spontaneous and free.
117417 posts in 3817 days
#5 posted 11-08-2012 12:17 AM
I tend to agree with David …. but if you feel you just must try some kind of veneering you could get some oak door skins trim them to size and apply some contact cement to both sides and apply them,this is not in a true sense real veneering but kitchen remodelers reface cabinets like this all the time.
View bondogaposis's profile
bondogaposis
5153 posts in 2591 days
#6 posted 11-08-2012 12:25 AM
I’d go with paint.
-- Bondo Gaposis
69BBNova
#7 posted 11-08-2012 12:37 AM
Leaving it alone may be the best idea, I havent gone further because I felt no matter what I tried it would have looked far worse than what it is…
I did think of paint, but over the years I’ve grown to dislike it for wood…
Thanks for the advise…
At least I dont think it will fall apart (I hope), it has 105 dowels, 50 screws and Titebond
View Earlextech's profile
Earlextech
1162 posts in 2930 days
#8 posted 11-08-2012 02:08 PM
Paint to hide the variation or clear coat to accentuate it.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3398 days
#9 posted 11-08-2012 02:25 PM
I think milk paint would look good.
-- jay, www.allaboutastro.com
69BBNova
#10 posted 11-08-2012 04:45 PM
I was planning on applying a poly clear coat, I didnt think it would help enough…
Didnt even consider testing if it would help.
I have to ask…what exactly is milk paint?
David Craig
#11 posted 11-08-2012 04:52 PM
Milk paint is a lime based or real milk water based finish. You can buy packages and mix it yourself. It is used to give some items, like your trunk, an antiquated look. You can cackle it to look like aged paint and use two colors to give it an interesting look. Basically, one dark color as a base and a lighter color that you partially wipe off so it looks like the piece is getting old and the topcoat is getting a bit worn. There are many online how-tos on the topic. It probably would look good on your trunk.
69BBNova
#12 posted 11-08-2012 05:04 PM
Thanks Cosmic for the idea.
And Thank You David for the additional info…
I’ll look into it, I just hope its look is nothing like modern finishes.
Cosmicsniper
#13 posted 11-08-2012 05:20 PM
Think Quaker with regard to milk paint.
View ADHDan's profile
ADHDan
800 posts in 2348 days
#14 posted 11-08-2012 06:52 PM
If you REALLY want to accentuate the wood differences maybe you could use different stains for different sections, taping off as you go to make crisp delineations? I don’t know if the stain would bleed through under the tape though. If that wouldn’t word, I agree with a clear coat to accentuate, or paint to hide differences.
-- Dan in Minneapolis, woodworking since 11/11.
View CharlesNeil's profile
CharlesNeil
2469 posts in 4110 days
#15 posted 11-08-2012 09:08 PM
If your game I have an idea, as most know I developed a blotch control that also seems to help alot in having various wood accept a dye or stain evenly, this looks like a prime candiate to test it to the Max, I am willing to send the BC as well as some dyes, to see what we can get this thing to look like, you game, My treat all the way
If so we will figure out what some coloring you would like and go from there,
Nothing Ventured Nothing Gained, will be out until Monday so replies may be slow until then just FYI
