ceiling storage in a pole barn...how much is too much?
Forum topic by shelly_b posted 223 days ago 1960 views 0 times favorited 22 replies Add to Favorites Watch
View shelly_b's profile
shelly_b
679 posts in 314 days
223 days ago
My shop is in a 30×40 pole barn. I would like to put storage up in the trusses, and have some of the shelves that hang from the ceiling also(really there is no ceiling right now, just the trusses and roof). The trusses span the 30ft and I am worried about putting to much weight on them. I really would rather not have any supports in the middle of my floor…I was wondering if I could just sister up to the truss with some 2×6s or bigger to strengthen them…or should I just limit my upper storage?
22 replies so far
857 posts in 690 days
#1 posted 223 days ago
This thread is of interest to me. I have a pole barn about that size and was wondering the same thing. In mine, the trusses are 8’ apart making it even harder to store anything. The barn isn’t my shop, but could be a lot more useful if I had overhead storage.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
View junebug's profile
junebug
53 posts in 601 days
#2 posted 223 days ago
really depends on your truss design. Did you have the barn put up, or was it an existing structure when you bought the property?
Most post frame trusses in my area are only designed to hold 5 or 10 pounds per square foot…. enough for drywall
View casual1carpenter's profile
casual1carpenter
260 posts in 672 days
#3 posted 223 days ago
shelly_b, You wonder if you could use the truss as attic storage but I think that you are correct to question this. Trusses are engineered which is a good thing, but, they are engineered to minimize cost weight etc with a calculated safety factor. 30’ is a long clear span and overloading could cause failure so I would propose the question to a truss manufacturer. Likely you will need some columns to lend additional support.
View crank49's profile
crank49
2376 posts in 1167 days
#4 posted 223 days ago
Can a truss be built that will span 30ft and carry additional attic load? YES
Would any builder do this if not specifically required to do so? NO
Adding sister members to the lower chord might help or it might hurt. Has to be engineered to know.
The only “non-engineered” way to add capacity for sure without risking collapse is to add posts at the points of additional loading.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View EEngineer's profile
EEngineer
778 posts in 1810 days
#5 posted 223 days ago
Oddly enough, I have been pondering the same thing. I wired and redid my garage shop this summer. I had already used the roof trusses for a lot of storage for long lumber, etc and had noticed some sag. In general, the research I did shows:
1. No, just sistering the trusses will not add much additional strength.
2. In my case, the trusses were 8 ft apart, also. I will have to add additional trusses to bring that down to 2 ft apart to support much load. I am also going to add extra bracing to the simple 2X6 cross-members that my garage was built with. All that they do is keep roof loading from pushing the sides of the garage out. With the span I have (18ft 2X6) load capacity is not even sufficient to support drywall ceiling.
3. When it is all said and done, I won’t get nearly the extra storage space or capacity I thought I would. We are not talking engine blocks here, just simple 1 to 2 layers of board and plywood storage.
4. There are lots of resources on the Web for these things. Do your research and run the math or you might end up with the entire thing on your head!
View Handtooler's profile
Handtooler
434 posts in 328 days
#6 posted 223 days ago
I’m certainly not a structural engineer, but have observer some beam barn and dock constructing of recent months. If they were constructed of LVL,(Laminated Veneer Lumber), across the span they can withstand a considerable load. If not maybe some additional LVL can be scabbed to, some not all , of the spaning members of the building and give you the necessary load capacity. My neighbor just had a two boat dock built and he uses just two LVL members to support his lift systems lifting boats of 5500 and 3200 lbs while using 6 additional 2X 8 trusses I think 8 ft apart. Search LVL and there are several engineering sources to provide info of strength of spans. Weyhouser being one. Do any of you, LJ’s have further experience in this matter. I’m also interested.
-- Russell Pitner Hixson, TN 37343 bassboy40@msn.com
View joeyinsouthaustin's profile
joeyinsouthaustin
563 posts in 269 days
#7 posted 222 days ago
Pictures of your existing trusses would help identify what kind of load they were engineered to hold.
-- Who is John Galt?
shelly_b
#8 posted 221 days ago
I will take a picture when I get home. I beleive they are 4ft apart, and are constructed of 2×4s. Adding more trusses with LVL sounds like a great idea. We built it last spring…so I will keep researching(and looking for an engineer) and if there are any more ideas let me know!
View Bluepine38's profile
Bluepine38
2161 posts in 1282 days
#9 posted 221 days ago
You did not mention the clearance to the bottom of the beams. To eliminate the center post in one garage, we
put a lam beam down the center supported on each end by posts. If you have plenty of head room, and money
you could put a small lam beam under each truss supported on each side by posts, but with your trusses at 4’
you might have to add a support beam every 2’ to give plenty of support to a floor, or to keep wood stored up
there from bowing between trusses.
-- As ever, Gus-the 74 yr young apprentice carpenter
shelly_b
#10 posted 220 days ago
Here are some pics of the roof. I beleive they are 4 ft apart…
A few big strong laminated beams sound like a good idea…I don’t know that we would have to add a support on the ends, I think just to the roof, though I am no engineer lol
shelly_b
#11 posted 220 days ago
And don’t mind the mess….I am working on the orginization lol.
View IrreverentJack's profile
IrreverentJack
668 posts in 1039 days
#12 posted 219 days ago
Shelly, Pole barn trusses are usually engineered to meet the specified snow load for your area and no more. If the roof is insulated or a ceiling installed, the trusses are built stronger to handle the extra weight. Putting an additional and asymmetrical load to a roof system having 2”x4” bottom cords on 4’ centers with a 30’ span and a 3-4 pitch in Western NY would be a bad idea. Might be different in your area. Talk to the builder or the folks that sold/made the trusses. -Jack
shelly_b
#13 posted 217 days ago
Ok, thanks:) I didn’t think they looked very strong…
joeyinsouthaustin
#14 posted 217 days ago
I don’t see an easy way to modify the trusses to hold any real load in the way you want to use them.
I do see adding lvl’s across at each post to create a joist system for storage. Would even be able to deck portions of it. You have full beams, it appears, on to of the posts that the trusses are set on, you could set the lvls in hangers, knotch for the roof, and end up storing alot. A knotch, and an angle cut would keep you from reducing the height of the shop that much and land your joist ties even with the truss ties for easy decking.
If you are interested I can do a hand drawing, and give an idea how tall and wide the lvls would need to be.
I have laid engineer designed “hanging floor trusses” in a similar type of space, but I think lvls would be cheaper.
shelly_b
#15 posted 216 days ago
joeyinsouthaustin-a drawing would be great, thank you! i agree, i think this is the only way to have overhead storage without damaging the roof. thank you:)
