Prep a cabinet before cleating it
Forum topic by Pauline posted 193 days ago 413 views 0 times favorited 9 replies Add to Favorites Watch
View Pauline's profile
Pauline
6 posts in 193 days
193 days ago
Greetings!
A neophyte here.
I have a ladies dresser vanity that I disassembled into 2 pieces. Each piece is a set of 2 small drawers that sit inside a cabinet frame. 16 depth by 13 in wide by height 22 in. The backing of the “cabinet” is a flimsy piece of thin press board. The cabinet frame housing the drawers is solid. I would like to cleat this “cabinet” but not sure what to do to the cabinet frame PRIOR to making the cleat. Can I simply swap out the back for a 3/4 inch plywood back and cleat or do I need to modify the frame in any way. Thanks.
9 replies so far
View cabmaker's profile
cabmaker
1022 posts in 975 days
#1 posted 193 days ago
You have my permission, but what do you mean by cleat ?
View waho6o9's profile
waho6o9
2881 posts in 743 days
#2 posted 193 days ago
French cleat it.
Pauline
6 posts in 193 days
#3 posted 193 days ago
I would like to French cleat it, but am not sure if all I need to do is provide a solid plywood back to the cabinet and then to apply a French cleat.
cabmaker
#4 posted 193 days ago
I presume your hanging this on the wall ? Applying a solid back is a plus. I would add a perimeter strip on the back to conceal the cleat at the top however..
waho6o9
#5 posted 193 days ago
Mount an angled cleat to the wall, install the complimentary cleat
to your project, and you can slide it to your desired location.
Welcome to LumberJocks Papuz!
cabmaker
#6 posted 193 days ago
Im out , I think you all are talking about two differant things.
waho6o9
#7 posted 193 days ago
Here’s a side view Papuz.
Pauline
6 posts in 193 days
#8 posted 192 days ago
I think I have my answers, but I have also learned to use full terminology and to provide specific details.
I can see how things can get confusing. I will be French cleating this cabinet to the wall about 10 in off the floor.
The perimter strip is a great idea., that was another concern. I may place a granite counter top on top of the existing surface top so this will work.
I really want to thank you for your help as this gives me a go ahead for my project….:)
waho6o9
#9 posted 192 days ago
U da man Papuz!
