2,000 grit sanding discs?
Forum topic by Purrmaster posted 11-06-2012 11:33 PM 1848 views 0 times favorited 2 replies Add to Favorites Watch
View Purrmaster's profile
915 posts in 2028 days
11-06-2012 11:33 PM
I’ve been looking for a source for 1,500 and 2,000 grit 6 inch sanding discs made by Norton abrasives. I’ve searched and searched and can’t find them. I’m 99% sure Norton manufactures sanding discs with grits that high. If for no other reason than the 1,000 grit discs you can buy from the Work Sharp people are Norton.
I’m looking for said discs to use on my Work Sharp. To be specific I’m hunting for 1,500 grit and above 6”, stick on sanding discs.
If anyone knows of a source for these discs, could you please point me the right direction?
Thank you.
2 replies so far
View Raymond Thomas's profile
Raymond Thomas
189 posts in 2154 days
#1 posted 11-07-2012 12:10 AM
If you can’t find them, make you own. Buy the full sized sheets, scribe & cut the circle to size and apply a tacky adhesive to the back.
-- Raymond, Charlotte, NC -------- Demonstrate the difference!
117032 posts in 3512 days
#2 posted 11-07-2012 12:19 AM
