| Forum topic by Ripthorn | posted 224 days ago | 599 views | 0 times favorited | 19 replies | ![]() |
224 days ago |
My table saw is an older Grizzly saw (early 80’s vintage) and as far as I know has the original motor and start capacitor. My shop is in an unheated garage and I noticed last year that when it was cold, the saw would trip the breaker on startup once or twice and then start up fine the 2nd or 3rd time. It has started getting cold here again (40’s in the shop or so) and the saw now trips the breaker every time and simply will not start up when it’s cold. The motor runs fine if it gets started, so I am thinking maybe the capacitor is not holding a charge, resulting in a large inrush current when I engage the power switch, causing the breaker to trip. Has anyone had a problem like this before and does this sound about right for a capacitor that is on it’s way out? Thanks. -- Brian T. - Exact science is not an exact science |
19 replies so far
#1 posted 224 days ago |
TRY this upgrade your breaker a notch to a slightly larger one seems you might be on borderline with the one fitted at present.Alistair -- excuse my typing as I have a form of parkinsons disease |
#2 posted 224 days ago |
Typically, when a cap goes, it goes quick.. but you could pull it and test with a meter pretty easily. I’d be more inclined to think that it might be a bearing problem given the age of the machine.. try turning it by hand to see if you feel resistance or hear noises.. take the belt off if it has one and try that way. Scotsman also brings up a good question.. what size circuit are you running that saw on and how much does it draw and do you have anything else running on it? Cheers, -- Brad in FL - To be old and wise, you must first be young and stupid |
#3 posted 224 days ago |
I think upsizing the breaker is asking for problems, it’s probably sized to the wiring and putting a higher capacity one in may lead to problems. But those caps can be easily tested…or if you don’t want to test, simply buy a new one. They are fairly cheap….I think I paid less than $10 for the last one I bought. Or, a motor shop could test it for you. I do think starting it up without the belt(s) on may help with the diagnosis. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#4 posted 224 days ago |
If it was me, I’d suspect either capacitor or bearings. Bearings are easy to check (does it spin easily?). You can check your capacitor with an ohm meter. It should start with a low resistance and ramp up to infinity. (make sure you short it out when you’re done). If it’s questionable, they’re pretty cheap to replace. -- Visualize whirled peas |
#5 posted 224 days ago |
You can tell if it is the capacitor if you hear a humming noise in the motor just before the breaker trips, but the motor is not really turning. My guess is either you have a weakening start winding which would raise the inrush amperage, or your breaker is weakening. -- Paul, Tennessee, http://www.tsunamiguitars.com |
#6 posted 224 days ago |
The motor is a TEFC motor, 1.5 HP, so running current should be less than 11 amps. The breaker is 15 amp and recently installed (put in a dual breaker in the place of the single that was there). Again, the motor starts fine when it is a little warmer, so it has to do with the cold somehow. As for dirty internal switch contacts, how likely is that on a TEFC motor? It is very likely that no motor maintenance has been performed in the last 25 years, motor is original, etc. The saw has worked quite well except for the cold startup issue. I was able to get it started about midday over the weekend, but in the evenings or early morning, it doesn’t like ot start. -- Brian T. - Exact science is not an exact science |
#7 posted 224 days ago |
When is it cold. Resistance is lower. From what I gather, you need to check the inrush current for the motor. http://en.wikipedia.org/wiki/Inrush_current |
#8 posted 224 days ago |
A 15 amp circuit is kind of marginal for a 1.5 horse motor. The starting current inrush could be several times full load. -- Visualize whirled peas |
#9 posted 224 days ago |
Ditto to what muleskinner said! -- "I never met a board I didn't like!" |
#10 posted 224 days ago |
If a motor is slow or hums on startup and the motor is fine if you give the pulley a hand (WATCH YOUR FINGERS!) then it is the start capacitor. Before I dug into the motor I’d take the switch apart, maybe just wire in a temporary new one (heavy duty 20 amp switch from hardware store is fine) and see if that is the problem. |
#11 posted 224 days ago |
so I am thinking maybe the capacitor is not holding a charge No, no, no! I refer you to wikipedia for an accurate but brief description of what the cap is for. Troubleshooting: you can disconnect the belt, turn on the power and if the motor starts with a quick twist of the motor pulley in the right direction, bet on a bad cap. If the motor is having problems when it is cold, I would be more inclined to look at the bearings. Interfernces all get tighter when cold. However, I wouldn’t rule out a bad cap. -- "Find out what you cannot do and then go do it!" |
#12 posted 224 days ago |
Ok, I phrased it slightly wrong. The capacitor is there to give an inrush in direction, which it does over and over as it charges and discharges. It also keeps the magnetic field slightly ahead of the rotor, causing it to “chase the magnetic field”, so the motor comes up to speed. If the rotor cannot keep up due to faulty bearings, excessive load, etc, the current rises, and the breaker trips. That is why when the cap is bad, you can still make the motor go one way or another by giving it a spin. (In some cases) You are advancing the magnetic field in a particular direction and the rotor will follow the magnetic field, since we’re dealing with AC. -- Paul, Tennessee, http://www.tsunamiguitars.com |
#13 posted 224 days ago |
So it is possibly the bearings that are going? I am curious as to why this would happen only in the cold. Also, I took the belt off and it is still tripping the breaker even with no blade to spin. I suppose that if the caps are not bad, then what is my path forward? I am supposing I can’t replace the bearings myself. Would this mean that the motor is starting to die a slow death? -- Brian T. - Exact science is not an exact science |
#14 posted 224 days ago |
Okay, so some more info. I had the belt off of it, gave the pulley a spin and hit the power button and it spun up just fine. Put the belt back on, hit the power button (no spinning help, I’m not that dumb) and it tripped the breaker. Does the extra info shed any extra light on the situation? -- Brian T. - Exact science is not an exact science |
#15 posted 224 days ago |
Start capacitor. |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15978 |
Hand Tools
2095 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2776 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
