| Forum topic by tturner | posted 224 days ago | 844 views | 0 times favorited | 9 replies | ![]() |
224 days ago |
Topic tags/keywords: jatoba brazilian cherry dresser shellac tung powermatic festool question modern finishing I have found Tung oil and i love it! Ive watched David Marks use it on nearly everything and now i know why! Enough said about that. If you know it, you know what I mean. My question is this-is it safe to spray shellac over the tung oil? How long should i wait? My current project is a Brazilian Cherry/Jatoba dresser. From the tests ive done, 2 coats of tung oil does magic. I bought blonde shellac and denatured alcohol yesterday from Woodcraft and im ready to experiment today! Thanks for all your generous info and comments. Dont be afraid to say ‘dont use shellac!’ But please give me a suggestion for something over the tung. Todd Turner -- I'm him |
9 replies so far
#1 posted 224 days ago |
If you are using REAL Tung Oil (as in pure tung oil, not the crap they sell that they CALL tung oil finish that actually has little or no tung oil in it…) then I wouldn’t shellac over it. At least not for quite a long time. Shellac is an evaporative finish. The tung oil is a reactive finish. You’d have to wait until the tung oil is completely done with gassing off and is catalyzed which can take weeks to months depending on conditions and application. Tung oil can be the finish. It just needs to be refreshed occasionally. I love tung oil. If you want more shine on tung oil, try putting on a few coats (letting it dry between) and then applying it with 0000 steel wool or 400 to 600 wet/dry paper. It will kind of slurry up on ya so you’d wipe off any excess slurry. Then when it’s almost dry, buff it with a power buffer, like what you’d use on a car. Just a dry buffing pad. Don’t put any wax or anything on it. You end up with a tight, nearly burnished surface with deep oil penetration. I use pure tung oil on flutes that I build. Some I like to have a matte finish (most of them), but once in a while I buff one up. It looks pretty amazing. |
#2 posted 224 days ago |
I’m far from being an expert but I’ve use just pure tung oil in two toys as a finish, and it was enough to protect the wood and give a mate finish. I’ve just applied two or three coats, letting it dry for a couple of days and light sanding before each coat. On a recent project (restoring an old wooden plane), I’ve use one light coat of tung oil and then wax. I’m quite impressed with the result, it looks like an old piece of furniture, the ones your gandparents had. I’m pretty sure the wax will go off some time, but I don’t care since it’s a tool and I plan to use it as such. One more thing I love about tung oil: the smell. I just love the smell of wood and tung oil. |
#3 posted 224 days ago |
Tung oil finish isn’t actually complete crap, but it’s not “tung oil”. It’s an oil/varnish blend with similar properties to danish oil. I use danish oil a lot and apply finish over it because it offers very little protection on it’s own. I generally give the piece AT LEAST 10 days, maybe more depending on temperature and humidity before I apply a finish. |
#4 posted 218 days ago |
Im using pure, 100% tung oil. There seems to be as many opinions for finishing as there are techniques, applications, concoctions, and options! I also looked at Waterlox and Arm r seal too. But do they do what tung oil does? Can i spray waterlox over tung? Charles Niel is correct to say, ‘start finishing before the project is started.’ im going to try a sample of shellac over the tung today and see what happens. I understand shellac isnt the hardest but pretty good. Another facet is the application for the project. Im currently making a hall dresser out of Brazillian Cherry. You guys are great!! -- I'm him |
#5 posted 218 days ago |
You haven’t said what you’re trying to achieve. For a no-gloss look, the tung oil is enough. If you want a finish with more depth and sheen, an oil based urethane or alkyd resin varnish will be the most compatible. If the tung is well cured, a waterborne would work. I wouldn’t use shellac. -- Clint Searl.............We deserve what we tolerate |
#6 posted 218 days ago |
tturner, you might want to web search 100% pure tung oil, there was a page someone recommended for a tung oil source, milk paint or something similar. The guys physical address was close to me and I called about a walk in sale, his web page contained a lot of information. I believe he said that the waterlox was a good choice to apply over the 100% tung oil but it was a while ago, but I do remember that there is a drying schedule. Perhaps Waterlox might be another good resource to call or email for proper information. |
#7 posted 218 days ago |
You can indeed put waterlox over pure tung oil. Instructions are on Waterlox’s web site. You can also call the folks at Waterlox and they’ll explain exactly what you need to do. Very good customer service and support from Waterlox. The “milk paint or something” source for pure tung oil is probably THIS one Another off-the-beaten-path finish I’ve found to be really nice is Osmo Poly-X Hard Wax Oil. It’s made to be a floor finish, but it makes a real nice, real repairable furniture finish as well. |
#8 posted 218 days ago |
Might be worth noting that a lot of what is called “tung oil” often is not pure tung oil – especially the stuff that get’s called “tung oil finish”. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
#9 posted 218 days ago |
If you are going to finish with shellac, apply some to bare wood and see how it looks. It pops grain quite nicely. if you like it, you can save your self 10 to 14 days of drying time after applying tung oil. |
| Forum | Topics |
Woodworking Skill Share
8842 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1597 |
3591 |
15972 |
Hand Tools
2093 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2772 |
LumberJocks.com Site Feedback
1551 |
Coffee Lounge
6130 |
