shellac as a sealer
Forum topic by Howie posted 195 days ago 490 views 0 times favorited 9 replies Add to Favorites Watch
View Howie's profile
Howie
2449 posts in 1089 days
195 days ago
I’ve been using Zinser dewaxed full strenght as a sealer. The directions say to cut it by 25%. Is that really necessary? I’m using it on poplar for a sanding sealer.
-- Don't rollerskate in a buffalo herd
9 replies so far
View Monte Pittman's profile
Monte Pittman
7040 posts in 504 days
#1 posted 195 days ago
I’m not that familiar with Shellac, but I have never cut it when I did use it.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
View Cosmicsniper's profile
Cosmicsniper
2148 posts in 1325 days
#2 posted 195 days ago
Not necessary if you are using it as a sealer. But if you are using it as a washcoat, I’d dilute it down by a half.
-- jay, www.allaboutastro.com
View NiteWalker's profile
NiteWalker
1467 posts in 743 days
#3 posted 195 days ago
If you mean the sealcoat, I use that a lot and never thin at all.
View Joe Lyddon's profile
Joe Lyddon
6377 posts in 2218 days
#4 posted 195 days ago
I would thin it to about a 1-2lb cut for a sealer with DNA…
You could probably add 1/3 more of DNA and it would work great for a sealer…
I don’t think I’d use it straight out of the can unthinned for a sealer… you’d be wasting shellac and I think you’d be sanding more too…
With a thinner cut, it would seal better, dry faster, and wouldn’t require as much sanding.
IMHO
86974 posts in 1743 days
#5 posted 195 days ago
Two applications of 1lb cut of dewaxed shellac, would be more effective. Your want better penetration to help control blotching on poplar.
NiteWalker
#6 posted 195 days ago
FWIW, sealcoat is a 2lb cut.
I’ve never had issues with drying time, sealing or sanding.
View Earlextech's profile
Earlextech
591 posts in 857 days
#7 posted 195 days ago
I always cut Sealcoat 50/50 with DNA.
-- Sam Hamory - The project is never finished until its "finished"!
View RogerM's profile
RogerM
316 posts in 565 days
#8 posted 195 days ago
I also cut Seal coat at least 50% when using as a sealer and sometimes as much as 75% for hard closed grain woods.
-- Roger M, Aiken, SC
Joe Lyddon
#9 posted 195 days ago
I was only 17% OFF!
50/50 sounds good!
I think I remember that Scott Phllipps does 50/50…
It isn’t super critical… but it sounds like you should be thinning it…
