What wax to use?
Forum topic by Triman posted 470 days ago 504 views 0 times favorited 12 replies Add to Favorites Watch
View Triman's profile
Triman
26 posts in 478 days
470 days ago
I see a number of projects listing wax as a final finish. I’m wondering what products you recommend? I’m looking to bring out the best in some curly and birdseye maple. I plan on starting out with a few coats of tung oil, but I see some people recommending a wax finish. Any suggestions?
Thanks,
Triman
-- Bruce, San Jose, Ca www.spotofwood.com
View sIKE's profile
sIKE
1094 posts in 650 days
470 days ago
This is a recipe I have seen floating around on some of the forums:
4 ounces beeswax
2 tablespoons carnauba wax
2 1/2 cups mineral spirits
Melt the wax (dbl broiler recommended) remove from fire, add the spirits and mix.
Apply with soft cloth turn as it gets dirty, let it dry then buff out.
Additional coats should be spaced out over a couple of days.
Hope this helps.
Updated for clarity…
View HokieMojo's profile
HokieMojo
1142 posts in 624 days
470 days ago
Mineral Spirits are flamable right? Might want to avoid open flame and take other precautions too. I don’t know much about this though.
teenagewoodworker
2482 posts in 664 days
470 days ago
you could also try a glaze. it will accent the grain and you can add a bit of color to it. if not i like antiquax wax, and renaissances wax.
View Joey's profile
Joey
259 posts in 711 days
470 days ago
i use a furniture paste wax over a mixture of raw tung oil, boiled linseed oil and poly blend. just use minwax or briwax. briwax does come in different shades for different colored wood.
-- Joey, Magee, Ms http://woodnwaresms.com
View tenontim's profile
tenontim
1319 posts in 640 days
470 days ago
Be advised, if you use Briwax or any other wax with toulene in it, make sure your finish has completely cured before use, other wise you could have finish problems. Check the ingredients and watch out for toulene and silicon.
-- Tim -- http://tmuli.com
View lethentymill's profile
lethentymill
58 posts in 505 days
469 days ago
Hope this is not stating the obvious but as Tim has said, “watch out for silicon”. I don’t know what toulene is (I’m in Scotland) – perhaps someone could tell me about that?! However, silicon is like a disease – it is almost impossible to completely remove it from a finished surface, even after planing and sanding there could still be traces, which will cause “sissing”. This is a painter and decorator’s word, which indicates blistering in the finish caused by substances like silicon.
This blistering rarely occurs on the first application. It usually happens on the second or third coat! If you ever encounter this, you know that silicon polish was used at some time. You may have to rub the whole surface down again and use finishing oil or shellac.
-- Allan Fyfe, Lethenty Mill Furniture, http://www.lethenty-mill.com
Douglas Bordner
3424 posts in 960 days
469 days ago
Allan, we on this side of the pond refer to this as “Fisheye”. There is little as disheartening than working a piece to the point of finishing only to encounter this.
I second Tenon Tim’s concernes about using Briwax before the finish has cured sufficiently. It will chew up uncured lacquer and shellac finishes.
I have a can of Trewax Indian Tan, which is now “Mahogany Brown”. It adds a subtle darkening to the finish.
I picked up a can 10 years ago, and there is still half a can to go.
Craft Supply USA, the turner’s resource has a host of wax products, should you find it difficult to find local sources.
Like Denny, I also use Renaissance Wax (Highland Wodworking), both as a final step in finishing and as a treatment for machine tables, which is especially important if you work out of unheated buildings in a climate with freeze/thaw cycles. It is a man-made microcrystalline wax, used by conservators in the cleaning of antiquities. A bit steep in price but a little goes a long way. Another version – Conservator’s Wax is available at Lee Valley.
MacGuiar’s car care products work well in the final rub-out of lacquer finishes too.
View Tony's profile
Tony
812 posts in 926 days
448 days ago
Hi there
I may be a little too late in giving you some advice on this subject. But I think you have the correct idea – start with an oil finish to “pop” the grain or features of the wood in question. you may find my blog on finishing useful.
The main thing is surface preperation – and if you want a really high sheen, then lots of sanding, lots of thin coats, each drying/hardening, before the next appliction and lots of time, you cannot rush this process.
Good luck I hope to see the project soon
View davidroberts's profile
davidroberts
242 posts in 382 days
317 days ago
I may be later than Tony on this subject. I read somewhere that it is only practical to apply one coat of wax because another coat will just remove the first coat. Take that FWIW. I do use a shoe brush dedicated to furniture after rubbing out with a soft cloth.
-- david roberts, houston area, "A little knowledge is a dangerous thing, but that has never been a problem for me."
View mgradwohl's profile
mgradwohl
190 posts in 709 days
317 days ago
+1 on Renaissance Wax. I find that I can do a few coats of wipe on poly (on a well sanded piece) and then after 24 hours go to the Ren Wax. It does a very nice job, leaves the surface smooth, shiny, and well… waxed.
View mski's profile
mski
360 posts in 876 days
317 days ago
Tung oil 50%, Carabuna wax 25%, Bees wax 25%.
Cook in double boiler, cool, Rub the heck out of it, or it into the wood.
-- MARK IN BOB, So. CAL
View Ekim's profile
Ekim
17 posts in 350 days
317 days ago
I believe Minwax makes a liquid wax that comes in colors that is easy to apply. Shoe polish works great too and it comes in many colors. I believe shoe polish is made with the wax that is taken from shellac when it is dewaxed.
Mike
-- mike, www.schoolofwood.com
