Dealing with rust on the table saw
Forum topic by spaids posted 111 days ago 384 views 0 times favorited 12 replies Add to Favorites
View spaids's profile
spaids
133 posts in 230 days
111 days ago
I have a Ridgid table saw. (3650) My shop is the garage. I am having some rust develope on the cast table. What do you recomend I do to remove the rust and what should I do to protect against rust in the future?
-- Total Freakin Newbie
View NY_Rocking_Chairs's profile
NY_Rocking_Chairs
277 posts in 134 days
111 days ago
Sand sand sand and then get some of the tool coating stuff…
I use this stuff:
http://www.rockler.com/product.cfm?page=2380
I am in a basement shop and run a dehumidifier which sucks about 1/2 gallon of water a day out of the air, but no rusting to speak of using the T-9.
-- Rich, WNY, www.nyrockingchairs.com
View Greg Wurst's profile
Greg Wurst
431 posts in 369 days
111 days ago
This is what I’ve used with very good results:
http://www.empiremfg.com/products/otc/ts/index.html
View Doug S.'s profile
Doug S.
217 posts in 245 days
111 days ago
I’ve used steel wool and WD40 with OK results – it’s gets most light surface rust off. But I recently switched to the same stuff Greg linked to when I had some more stubborn problems. It works quite a bit better than WD40. Follow that up with a coat of paste wax and you can reduce how often you have to clean it.
-- Use the fence Luke
NY_Rocking_Chairs
111 days ago
The wax also provides good lubrication. Part of the kit I gets includes a spray on wax like coating, but paste wax is cheaper and easier to apply.
spaids
111 days ago
As a newbie I started freaking out a bit when I saw rust on my table saw. I know its a low level table saw that I have but I don’t plan on ever upgrading and just because it was relatively inexpensive to other saws doesn’t mean that I love it any less. Thanks for the advice and the links! It seems that its an issue that a lot of us deal with.
View flink's profile
flink
95 posts in 257 days
111 days ago
I stuck a piece of scotch-brite on my random orbital sander. Worked great. But I now wax the table regularly.
-- Made lots of sawdust and pounded some nails. Haven't finished anything, though.
View sIKE's profile
sIKE
605 posts in 291 days
111 days ago
I use Boeshields Rust Free rust remover then clean that up with glass cleaner and make sure that it dries quickly. I then use Staples Crystal Clear Wax on the top and let it dry and then reapply. One of the things to consider is how hot your shop gets, I was told that the Staples brand wax has a bit higher melting point than the Briwax brand. I live in Texas and so far we have had of 46 days of 100+ weather this summer and my saw top is still slick and wood glides across it like a hockey puck with only one re-application needed.
View bbqking's profile
bbqking
279 posts in 260 days
111 days ago
Get the rust off. You probably will still have vestiges of it but that’s the way it goes. I coat all my milled castings with Turtle Wax from wherever you want to buy it. Works great. There was another forum about this awhile back and nearly everyone uses some type of auto wax. bbqKing
-- bbqKing, Lawrenceville
View Grumpy's profile (online now)
6717 posts in 388 days
111 days ago
Spaids, if you search ‘rust’ at the top of the LJ’s page you will find heaps.
View marcb's profile
marcb
199 posts in 210 days
111 days ago
I live in the Midwest which is humid in the summer and in the winter and in the fall and…
My shop is in a 3 stall garage that is not attached to the house. My heater is an unvented Natrual gas unit that hangs on the wall. So moisture in the shop can be an issue.
All that said all I use is a can of wax I bought at one oft he big box hardware stores by the steel wool.
I put it on thick and buff it off. I do this every monthish or whenever I have a minute in the shop I tend to wax my Bandsaw, Table Saw and Drill press. They’re slick, smooth and rust free.
View fredf's profile
fredf
228 posts in 247 days
103 days ago
bbqking don’t most auto waxes contain silicone?? BIG NO – NO! (can you say fish-eye??)
-- Fred, Springfield, Ma
View motthunter's profile
motthunter
1234 posts in 336 days
102 days ago
I use the empire kit.. works great and more importantly.. its easy to use
-- making sawdust....
Bookmark And Share This Page
