Whistling Dixie
Forum topic by airfieldman posted 196 days ago 815 views 0 times favorited 8 replies Add to Favorites Watch
View airfieldman's profile
airfieldman
154 posts in 1978 days
196 days ago
Topic tags/keywords: dust collection trouble shoot question
I was in a big box store recently and stumbled on a 20’ hose intended for a washer and realized it would fit my small shop vac hose, enabling me to reach my entire shop from a fixed position. And it was less than 10$! About half the price as a brand name hose with twice the length.
From there I decided to pick up a simple bucket and make another Thien dust separator. Worked like a champ! I used a larger diameter hose out of the bucket so that with a couple of simple diameter converters I could switch from a fixed floor intake (sweep to the port and dust, shavings, etc. just disappear!), to the long hose.
Again, this all worked beautifully. EXCEPT, the long hose has a very loud, high pitched whistle. Not exactly optimum. Any suggestions?
-- Measure with a micrometer, mark with a crayon, cut it with a chainsaw.
8 replies so far
View casual1carpenter's profile
casual1carpenter
250 posts in 642 days
#1 posted 196 days ago
airfieldman, the big vac trucks I’ve used on the job do that at high vac suction levels. I sort of wonder if the dia. and perhaps a spiral combined with length are creating resistance and starving the shop vac for air. I could be wrong but I believe that the whistle is caused by the rotation turbulence at high velocity. Is there any way to provide additional inlet opening, like a tee or wye, at or near the vac that you could adjust to optimize airflow, suction, and whistle? No guarantees to stop the whistle, just a passing thought. Any way, it was just a thought so good luck and how bout some ear plugs if you don’t resole the issue. Tone deafness is very real and common in my trade, not a lot of fun.
airfieldman
#2 posted 195 days ago
That makes a lot of sense. As I covered the nozzle, the whistle stopped (obviously…). And as I slowly removed my hand, there was a point where the whistling started…not immediately upon resumption of any suction, but a break point if you will.
The problem that hightlighted was that the suction generated caused greater pressure than the bucket could accomodate. Will have to re-due the bucket with a tin version.
casual1carpenter
#3 posted 195 days ago
airfieldman, Your plastic bucket should have been fine as long as the inlet nozzle remains somewhat clear for air passage to feed the vacs cubic feet per minute of air. I think what is going on is sort of the reverse of the linked description. But it is just a guess.
http://www.americanwhistle.com/how.html
airfieldman
#4 posted 194 days ago
That is an interesting theory. Hadn’t looked at it quite that way before. Thanks. I am starting to believe it has to do with the reduction of volume allowed when switching from the wider, 2.5” to the 1.25” tubes. The resulting sound is similar to those noise makers that were everywhere during the last summer olympics. Can’t remember what they were called…
casual1carpenter
#5 posted 194 days ago
View DaveFFMedic's profile
DaveFFMedic
67 posts in 334 days
#6 posted 182 days ago
Your problem reminds me of my furnace. The cold air return duct has a 1/4” hole drilled in it. When I asked the HVAC repair man what the hole was for, he explained that it was an old trick installers used to use to eliminate any whistle. It seems to work because my furnace does not whistle. I think casual1carpenter has the right idea. You need to provide another inlet near the vacuum. Whether you drill a hole in you hose or add a wye…
View Craftsman70's profile
Craftsman70
137 posts in 292 days
#7 posted 181 days ago
I’ve had this happen to when I bought sump pump hose to use for the shopvac. Everything I’ve read says its the high velocity of the air going through the corrigated hose. I’m looking at replacing that hose with either a larger diameter which will slow down the air speed, or finding hose with a smooth interior. Smooth walled hose would be best, but I haven’t found a cheap source.
airfieldman
#8 posted 167 days ago
AH-HA! I found an answer finally! It’s explained real well on this webpage. But to boil it down, it’s because the ribs are TOO symetrical. So changing the spacing on them (via heat) occasionally fixes that problem!
